Example S32K144 DMA memory copy test S32DS
* Detailed Description:
* This example shows how to init DMA for simple memory to memory copy.
* Eight 16-bit values are copied upon SW start.
* Test HW:         FRDM-S32K144
* MCU:             PS32K144HFVLL 0N77P
* Fsys:            default
* Debugger:        S32DS
* Target:          internal_FLASH
Original Attachment has been moved to: Example-S32K144-DMA-RAM2RAM-test-v1_0-S32DS.zip
コメント
Could you send this example? The linkage is invalide. Thanks
CY9
Invalid Parameters Specified
An invalid set of parameters has been specified in the url.
50%が役に立ったと言っています (1/2)
バージョン履歴
最終更新日:
‎10-14-2016 01:22 AM
更新者:
