* Detailed Description:
* This example shows how to init DMA for simple memory to memory copy.
* Eight 16-bit values are copied upon SW start.
* Test HW: FRDM-S32K144
* MCU: PS32K144HFVLL 0N77P
* Fsys: default
* Debugger: S32DS
* Target: internal_FLASH
Original Attachment has been moved to: Example-S32K144-DMA-RAM2RAM-test-v1_0-S32DS.zip
Could you send this example? The linkage is invalide. Thanks
