What will it impact for running bootloader project on s32g3
已解决
跳至解决方案
2,409 次查看
fengxianeric
Hello, I imported bootloader project (Integration_Reference_Examples_S32G3_2023_02), and got warning messages after loading configurations,
Thanks firstly
1 解答
2,285 次查看
Daniel-Aguirre
For our setup, we are seeing the same messages you are seeing:
Still, we can compile and run the bootloader no problem. We are not seeing any problem by ignoring these messages.
Please, let us know.
在原帖中查看解决方案
5 回复数
2,380 次查看
Bio_TICFSL
Thats mean that the T40012 is not matched with your current design, you have to checked this on swMinor and Mayor version, if you don't have the T40012 that you can avoid this warning.
2,372 次查看
fengxianeric
Thanks.
Included in RTD sw ?
2,319 次查看
Daniel-Aguirre
We assume this is referring to the following thread:
How to remove warning error for s32g3 bootloader p... - NXP Community
Is this correct?
2,302 次查看
fengxianeric
Thanks buddy caring 2 topics.
About this topic I want to know what it will impact if I ignored warning message even though it did not block compilation.
2,286 次查看
Daniel-Aguirre
