Hello, I imported bootloader project (Integration_Reference_Examples_S32G3_2023_02), and got warning messages after loading configurations,
Thanks firstly
解決済! 解決策の投稿を見る。
For our setup, we are seeing the same messages you are seeing:
Still, we can compile and run the bootloader no problem. We are not seeing any problem by ignoring these messages.
Please, let us know.
Thats mean that the T40012 is not matched with your current design, you have to checked this on swMinor and Mayor version, if you don't have the T40012 that you can avoid this warning.
We assume this is referring to the following thread:
How to remove warning error for s32g3 bootloader p... - NXP Community
Is this correct?
