Toggle GPIO from S32G2 linux image
2,140件の閲覧回数
Vishnu3
Hi all,
I am using the fsl-auto-image and i would like to write a c file which can be used to toggle the LED pins (using libgpiod) on my S32G-VNP development board. Any resources are also fine. I am looking for a basic template snippet, I don't need the whole code as I am fairly new to embedded linux.
I have already taken a look at the GPIO section in the NXP linux BSP 33 pdf but those only show the library APIs that needs to be called from the terminal.
Also, is it just the code or do I have to also make changes in the dts?
@chenyin_h  tagging you because you have been always so very helpful.
Best,
Vishnu
タグ(2)
2,109件の閲覧回数
chenyin_h
Hello, @Vishnu3
Thanks for your reply.
On BSP, the libgpiod-tools is supported, which could be used to control the GPIO from user space. directly execute the command from shell could display and control the GPIO status.
If these commands could not fully fulfill your requirements, I suggest reference the code of libgpiod,  to  apply your own modification on it if needed.
https://github.com/brgl/libgpiod
Chenyin
3 返答(返信)
2,110件の閲覧回数
chenyin_h
Hello, @Vishnu3
Chenyin
2,126件の閲覧回数
chenyin_h
Hello, @Vishnu3
Thanks for your post.
May I know which version BSP you are working with? based on BSP33?
Chenyin
2,121件の閲覧回数
Vishnu3
Hi Chenyin,
The BSP image I'm using is version 42. I've been referring to the document version 33, since I couldn't find the document for the latest version.
Best,
Vishnu
%3CLINGO-SUB%20id%3D%22lingo-sub-1993386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G2%20linux%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%81%AEGPIO%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AFfsl-auto-image%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81S32G-VNP%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AELED%E3%83%94%E3%83%B3%E3%82%92(libgpiod%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6)%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8Bc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%82%93%E3%81%AA%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BFLinux%E3%81%AB%E3%81%8B%E3%81%AA%E3%82%8A%E6%96%B0%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E5%85%A8%E4%BD%93%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%ABNXP%20linux%20BSP%2033%20pdf%E3%81%AEGPIO%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%8B%E3%82%89%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AAAPI%E3%81%AE%E3%81%BF%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82dts%E3%81%AB%E3%82%82%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%84%E3%81%A4%E3%82%82%E3%81%A8%E3%81%A6%E3%82%82%E8%A6%AA%E5%88%87%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E3%82%BF%E3%82%B0%E4%BB%98%E3%81%91%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%80%E8%89%AF%3C%2FP%3E%3CP%3E%E3%83%B4%E3%82%A3%E3%82%B7%E3%83%A5%E3%83%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E
