S32G3 Bootloader
3,876件の閲覧回数
jiajun_cheng
Hi,NXP Team:
Recently, I have been doing multi-core booting of S32G3 according to AN13750 and S32G_Bootloader_G3_LLCELOGGER_V1_2023_12_0.pdf, but it has been successful on S32G2-VNP-RDB2, but S32G3-VNP-RDB3 has not started yet. I would like to ask what needs to be modified for the multi-core booting of S32G2 and G3. Of course, the loading address has been modified.
S32G-VNP-RDB3
3,613件の閲覧回数
jiajun_cheng
我想我的问题已经解决了,应该是ATF的时钟没有匹配,修改ATF始终后,目前能正常运行
6 返答(返信)
3,606件の閲覧回数
chenyin_h
Hi, @jiajun_cheng
抱歉最近太忙,没能及时回复,一般AN13750相关的问题我们主要是建议查A&M两端的时钟和pin两个方面。
很高兴您的问题已经得到了解决,后续有其他问题您可以随时联系我们。
Chenyin
3,783件の閲覧回数
chenyin_h
您好, @jiajun_cheng
抱歉这几天有些繁忙,因为时间关系,我还没能仔细测试这种组合(BSP41 + Mcore),请问您是否方便A核端测试一下BSP42是否有类似问题?您之前测试成功的RDB2的case,也是基于BSP41吗?
Chenyin
3,774件の閲覧回数
jiajun_cheng
Hi, @chenyin_h :
1. BSP42我刚刚尝试过也是不行的
2. S32G2上我是跟随AN13750,使用的BSP33
今天看到有篇文章中提到,S32G2的A核的是1GHZ,S32G3是1.3GZH,所以需要修改A核的时钟是吗?如果需要的话,还请指导我怎么在ATF中修改
另外如果还有其他与G2不一样的地方,还请指导一下我,谢谢您
3,614件の閲覧回数
jiajun_cheng
3,825件の閲覧回数
chenyin_h
Hello, @jiajun_cheng
Thanks for your post.
From my understanding, AN13750 is based on RDB2, while the other file you mentioned is based on RDB3, for RDB3, you may reference the software packages needed from S32G_Bootloader_G3_LLCELOGGER_V1_2023_12_0, note that the bootloader base sample is from the S32G3 Platform Software Integration 2023.02.
Besides, there are not much differences between the test on RDB2 and RDB3 from my experience, since you have done the test on RDB2, I believe that there would not be many issues on running it with RDB3,  may I know if there are any specific issues met?
Chenyin
3,808件の閲覧回数
jiajun_cheng
Hi, @chenyin_h :
是这样的,我在C:\NXP\Integration_Reference_Examples_S32G3_2023_02\applications\realtime\Tresos\workspaces\Bootloader_S32G3XX_ASR_4.4_M7的基础上,按照AN13750的修改,但是从Norflash启动,我的A核并没有启动,请您帮我分析下有哪些原因,以下是我的一些配置
1. Bootloader配置,取消了Secure Boot,失能了Rm,Crypto,CryptoDal,删除了SysDal->PowerUp->Deinit->RmInit
劳特巴赫的调试,已经可以正常运行到WFI,所以是否已经代表Bootloader已经运行成功了,但是后续我的A核却并没有启动
2. Bootloader-> BootSource的地址配置
我的ATF分支也切换到了BSP41
编译产物的地址,我计算0x342f86c0+0x1240+0x34600=0x3433 1EC0,应该没有跟我的M7_0地址有冲突
这是我的IVT视图
最后将Bootloader,fip.bin,m7_app.bin,按照0,0x10 0000,0x20 0000的顺序烧录到Norflash,拨码开关也调到了Norflash启动的位置
所以还请您帮我检查下,应该怎么修改,谢谢~
%3CLINGO-SUB%20id%3D%22lingo-sub-2006502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G3%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%83%81%E3%83%BC%E3%83%A0%3A%3C%2FP%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81AN13750%E3%82%84S32G_Bootloader_G3_LLCELOGGER_V1_2023_12_0.pdf%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6S32G3%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81S32G2-VNP-RDB2%E3%81%A7%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81S32G3-VNP-RDB3%E3%81%AF%E3%81%BE%E3%81%A0%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82S32G2%E3%81%A8G3%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%8A%E8%81%9E%E3%81%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E3%83%AD%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32G-VNP-RDB3%2Fpd-p%2FS32G-VNP-RDB3%22%20class%3D%22lia-product-mention%22%20data-product%3D%222478-1%22%20target%3D%22_blank%22%3ES32G-VNP-RDB3%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2011814%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20Bootloader%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011814%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241854%22%20target%3D%22_blank%22%3E%40jiajun_cheng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E8%BF%91%E5%BF%99%E3%81%97%E3%81%8F%E3%81%A6%E8%BF%94%E4%BF%A1%E3%81%8C%E9%96%93%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%80%81AN13750%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81A%26amp%3BM%E3%81%AE%E4%B8%A1%E7%AB%AF%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%83%94%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2011719%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20Bootloader%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011719%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82ATF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82ATF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008166%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20Bootloader%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008166%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%26nbsp%3B%3A%3C%2FP%3E%3CP%3E1.%20BSP42%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E2.%20S32G2%E3%81%A7%E3%81%AF%E3%80%81AN13750%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6BSP33%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E6%97%A5%E3%80%81S32G2%E3%81%AEA%E3%82%B3%E3%82%A2%E3%81%AF1GHz%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81S32G3%E3%81%AEA%E3%82%B3%E3%82%A2%E3%81%AF1.3GHz%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E8%A8%98%E4%BA%8B%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82A%E3%82%B3%E3%82%A2%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81ATF%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EG2%E3%81%A8%E3%81%AE%E4%BB%96%E3%81%AE%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008132%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20Bootloader%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008132%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241854%22%20target%3D%22_blank%22%3E%40jiajun_cheng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9C%80%E8%BF%91%E3%81%AF%E5%BF%99%E3%81%97%E3%81%8F%E3%80%81%E6%99%82%E9%96%93%E3%81%AE%E5%88%B6%E7%B4%84%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%EF%BC%88BSP41%20%2B%20Mcore%EF%BC%89%E3%82%92%E3%81%98%E3%81%A3%E3%81%8F%E3%82%8A%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82A%E3%82%B3%E3%82%A2%E3%81%A7BSP42%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E4%BB%A5%E5%89%8D%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%9FRDB2%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%82BSP41%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2007645%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3%20Bootloader%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2007645%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%20%3A%3CBR%20%2F%3E%E3%81%93%E3%82%93%E3%81%AA%E6%84%9F%E3%81%98%E3%81%A7%E3%81%99%E3%80%82C%3A%5CNXP%5CIntegration_Reference_Examples_S32G3_2023_02%5Capplications%5Crealtime%5CTresos%5Cworkspaces%5CBootloader_S32G3XX_ASR_4.4_M7%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%ABAN13750%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Norflash%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%ABA%E3%82%B3%E3%82%A2%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%AE%E5%88%86%E6%9E%90%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%AB%E3%80%81Rm%E3%80%81Crypto%E3%80%81CryptoDal%E3%81%AE%E7%84%A1%E5%8A%B9%E5%8C%96%E3%80%81SysDal-%26gt%3BPowerUp-%26gt%3BDeinit-%26gt%3BRmInit%E3%81%AE%E5%89%8A%E9%99%A4%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_0-1733360862777.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_0-1733360862777.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314170i570CD0F2B4DA817C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_0-1733360862777.png%22%20alt%3D%22jiajun_cheng_0-1733360862777.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ELauterbach%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AFWFI%E3%81%BE%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81Bootloader%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%9F%E3%81%A0%E3%80%81%E7%A7%81%E3%81%AEA%E3%82%B3%E3%82%A2%E3%81%AF%E3%81%9D%E3%81%AE%E5%BE%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_1-1733360976728.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_1-1733360976728.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314171iE47576E35E6AFDCE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_1-1733360976728.jpeg%22%20alt%3D%22jiajun_cheng_1-1733360976728.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2.%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%20-%26gt%3B%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_2-1733361045803.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_2-1733361045803.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314172i23CFBDA1FEF1E19B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_2-1733361045803.png%22%20alt%3D%22jiajun_cheng_2-1733361045803.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEATF%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%82BSP41%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_3-1733361136802.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_3-1733361136802.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314173i8EBC6CCAFECEFAD6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_3-1733361136802.png%22%20alt%3D%22jiajun_cheng_3-1733361136802.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0x342f86c0%2B0x1240%2B0x34600%3D0x3433%201EC0%E3%81%A8%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%80%81M7_0%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E7%AB%B6%E5%90%88%E3%81%97%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_4-1733361185147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_4-1733361185147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314174iD95C89998B1BAEE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_4-1733361185147.png%22%20alt%3D%22jiajun_cheng_4-1733361185147.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AEIVT%E3%81%AE%E8%A6%8B%E8%A7%A3%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_5-1733361422792.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_5-1733361422792.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314175iD08590223A05008C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_5-1733361422792.png%22%20alt%3D%22jiajun_cheng_5-1733361422792.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81fip.bin%E3%80%81m7_app.bin%E3%80%810%E3%80%810x10%E3%81%AE%E5%BE%8C%E3%81%AB%E7%B6%9A%E3%81%8F0000%2C0x20%200000%20%E3%81%8C%20Norflash%20%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%80%81DIP%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%82%20Norflash%20%E3%81%AE%E8%B5%B7%E5%8B%95%E4%BD%8D%E7%BD%AE%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BF%AE%E6%AD%A3%E6%96%B9%E6%B3%95%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%9C%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2006883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AS32G3%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241854%22%20target%3D%22_blank%22%3E%40jiajun_cheng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81AN13750%E3%81%AFRDB2%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFRDB3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81RDB3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81S32G_Bootloader_G3_LLCELOGGER_V1_2023_12_0%E3%81%8B%E3%82%89%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3CSPAN%3E%E3%81%8C%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E5%9F%BA%E6%9C%AC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF%3CSPAN%20class%3D%22fontstyle0%22%3ES32G3%20Platform%20Software%20Integration%202023.02%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%8B%E3%82%89RDB2%E3%81%A8RDB3%E3%81%A7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%AA%E9%81%95%E3%81%84%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81RDB2%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81RDB3%E3%81%A7%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22fontstyle0%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%83%81%E3%82%A7%E3%83%B3%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
