Troubleshoot the GoldVIP setup on the S32G-VNP-RDB3 demo board
DRAVE
Hi NXP,
We are setting up the GOLDVIP development environment. We set up the GoldVIP Yocto project in accordance with Section 25 of document GoldVIP-S32G3-1.12.0-user-manual.pdf. We could not find the HSE firmware release. Can you tell me what to do?
1. We installed HSE-FW_S32G3XX_0_2_22_0.exe in windows and packaged the installation directory under ubuntu20.04 linux.
2. Configure local.conf:
3. bitbake fsl-image-goldvip
The following error occurs:
Can you tell me what the problem is? Thank you!
GuilhermeS32G
Hello @DRAVE ,
For being able to successfully downloading the Docker image without using VPN, please update the Yocto recipe
meta-gvip/recipes-containers/k3s/k3s_%.bbappend
By replacing lines 44 and 45 by:
skopeo --override-arch arm64 copy --additional-tag="docker.io/${PAUSE_CONTAINER_TAG}" \
        docker://dockerpull.org/${PAUSE_CONTAINER_TAG} docker-archive:${WORKDIR}/pause-container.tar
This should tell skopeo to use a Docker Registry mirror (dockerpull.org) instead of the default option. This should do the trick.
Guilherme
chenyin_h
Hello, @DRAVE
Thanks for your post.
I suggest modify the local.conf with the following line:
NXP_FIRMWARE_LOCAL_DIR = "/home/workspace/S32G"
You may edit it and retry the Yocto building.
Chenyin
DRAVE
Hi @chenyin_h
No errors are reported after I configure NXP_FIRMWARE_LOCAL_DIR according to your suggestions. I have a new problem. I can't seem to get xml-commons-resolver1.1-native-1.2-r1, xalan-j-native-2.7.1-r2, and avalon-framework-api-native-4.3-r1.
The website is as follows:
https://archive.apache.org/dist/xml/commons/xml-commons-resolver-1.2.tar.gz
https://archive.apache.org/dist/xml/xalan-j/xalan-j_2_7_1-src.tar.gz
https://archive.apache.org/dist/excalibur/avalon-framework/source/avalon-framework-api-4.3-src.tar.g...
I also couldn't get the file using Google Chrome under windows:
Do not have permission to access this resource?
Can you help me find out why? Thank you!
Tags (2)
GuilhermeS32G
Hello @DRAVE ,
These missing files can be downloaded through the Web Archive or through mirrors.
  • xml-commons-resolver: link
  • xalan: link
  • avalon-framework-api: link
As you may need a VPN for downloading these files, I attached them to the reply.
Once downloaded, place them in your Downloads folder.
Guilherme
DRAVE
Hi @GuilhermeS32G
Thank you for your reply! I put them in my downloads folder and that problem is solved. I have a new problem. Problems with compiling k3s:
log:
Initialising tasks: 100% |############################################################################################################| Time
Sstate summary: Wanted 21 Local 0 Mirrors 0 Missed 21 Current 3593 (0% match, 99% complete)
NOTE: Executing Tasks
ERROR: k3s-v1.25.8+k3s1-r0 do_fetch_pause_container: ExecutionError('/home/workspace/s32g/nxp-yocto-goldvip/build_s32g399ardb3goldvip/tmp/woa53-crypto-fsl-linux/k3s/v1.25.8+k3s1-r0/temp/run.do_fetch_pause_container.32385', 1, None, None)
ERROR: Logfile of failure stored in: /home/workspace/s32g/nxp-yocto-goldvip/build_s32g399ardb3goldvip/tmp/work/cortexa53-crypto-fsl-linux/k3+k3s1-r0/temp/log.do_fetch_pause_container.32385
Log data follows:
| DEBUG: Executing shell function do_fetch_pause_container
| time="2024-12-10T07:39:11Z" level=fatal msg="initializing source docker://rancher/mirrored-pause:3.6: pinging container registry registry-io: Get \"https://registry-1.docker.io/v2/\": dial tcp: lookup registry-1.docker.io on 10.86.240.241:53: read udp 172.17.0.8:40057->10.86.24 i/o timeout"
| WARNING: /home/workspace/s32g/nxp-yocto-goldvip/build_s32g399ardb3goldvip/tmp/work/cortexa53-crypto-fsl-linux/k3s/v1.25.8+k3s1-r0/temp/run_pause_container.32385:164 exit 1 from 'skopeo --override-arch arm64 copy --additional-tag="docker.io/rancher/mirrored-pause:3.6" docker://rrrored-pause:3.6 docker-archive:/home/workspace/s32g/nxp-yocto-goldvip/build_s32g399ardb3goldvip/tmp/work/cortexa53-crypto-fsl-linux/k3s/v1.-r0/pause-container.tar'
| WARNING: Backtrace (BB generated script):
| #1: do_fetch_pause_container, /home/workspace/s32g/nxp-yocto-goldvip/build_s32g399ardb3goldvip/tmp/work/cortexa53-crypto-fsl-linux/k8+k3s1-r0/temp/run.do_fetch_pause_container.32385, line 164
| #2: main, /home/workspace/s32g/nxp-yocto-goldvip/build_s32g399ardb3goldvip/tmp/work/cortexa53-crypto-fsl-linux/k3s/v1.25.8+k3s1-r0/to_fetch_pause_container.32385, line 168
ERROR: Task (/home/workspace/s32g/nxp-yocto-goldvip/sources/meta-virtualization/recipes-containers/k3s/k3s_git.bb:do_fetch_pause_container) th exit code '1'
NOTE: Tasks Summary: Attempted 8504 tasks of which 8498 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message, returning a non-zero exit code.
Bitbake failed
Do I need a VPN to download these K3s files? Could you please send me the relevant documents of k3s? Thank you!
GuilhermeS32G
Hello @DRAVE ,
The error that you are seeing refer to the following Yocto recipe:
https://github.com/nxp-auto-goldvip/meta-gvip/blob/develop/recipes-containers/k3s/k3s_%25.bbappend#L...
More specifically, to this part:
do_fetch_pause_container() {
    rm -f ${WORKDIR}/pause-container.tar
        docker://${PAUSE_CONTAINER_TAG} docker-archive:${WORKDIR}/pause-container.tar
It is attempting to use the Skopeo tool for copying the Docker image rancher/mirrored-pause:3.6. However, the address https://registry-1.docker.io/v2/ is blocked in China.
If you have the option of using a VPN to fetch this file, this would be the easiest approach.
I will take a look and see if there is a way to manually bypass this step. If I find something, I will give you a feedback.
Guilherme
GuilhermeS32G
Hello @DRAVE ,
Guilherme
DRAVE
Hi @GuilhermeS32G
Thank you for your reply. I do as your method. I successfully built the GoldVIP Yocto project. Thank you very much!
%3CLINGO-SUB%20id%3D%22lingo-sub-2009765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETroubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2009765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%2C%3C%2FP%3E%3CP%3EWe%20are%20setting%20up%20the%20GOLDVIP%20development%20environment.%26nbsp%3BWe%20set%20up%20the%20GoldVIP%20Yocto%20project%20in%20accordance%20with%20Section%2025%20of%20document%20GoldVIP-S32G3-1.12.0-user-manual.pdf.%26nbsp%3BWe%20could%20not%20find%20the%20HSE%20firmware%20release.%26nbsp%3BCan%20you%20tell%20me%20what%20to%20do%3F%3C%2FP%3E%3CP%3E1.%26nbsp%3BWe%20installed%20HSE-FW_S32G3XX_0_2_22_0.exe%20in%20windows%20and%20packaged%20the%20installation%20directory%20under%20ubuntu20.04%20linux.%3C%2FP%3E%3CP%3E2.%20Configure%20local.conf%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_0-1733727197982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_0-1733727197982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314737iB8B82DA80849B9CA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DRAVE_0-1733727197982.png%22%20alt%3D%22DRAVE_0-1733727197982.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3.%26nbsp%3Bbitbake%20fsl-image-goldvip%3C%2FP%3E%3CP%3EThe%20following%20error%20occurs%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_1-1733727270507.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_1-1733727270507.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314738iD5FB817476A029F4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DRAVE_1-1733727270507.png%22%20alt%3D%22DRAVE_1-1733727270507.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECan%20you%20tell%20me%20what%20the%20problem%20is%3F%20Thank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2009765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGoldVIP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2011508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241130%22%20target%3D%22_blank%22%3E%40GuilhermeS32G%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20reply.%26nbsp%3BI%20do%20as%20your%20method.%26nbsp%3BI%20successfully%20built%20the%20GoldVIP%20Yocto%20project.%26nbsp%3BThank%20you%20very%20much!%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_0-1733886203611.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_0-1733886203611.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315219iC9ED31F271CE4327%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DRAVE_0-1733886203611.png%22%20alt%3D%22DRAVE_0-1733886203611.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2011399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211314%22%20target%3D%22_blank%22%3E%40DRAVE%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFor%20being%20able%20to%20successfully%20downloading%20the%20Docker%20image%20without%20using%20VPN%2C%20please%20update%20the%20Yocto%20recipe%3C%2FP%3E%3CP%3Emeta-gvip%2Frecipes-containers%2Fk3s%2Fk3s_%25.bbappend%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBy%20replacing%20lines%2044%20and%2045%20by%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eskopeo%20--override-arch%20arm64%20copy%20--additional-tag%3D%22docker.io%2F%24%7BPAUSE_CONTAINER_TAG%7D%22%20%5C%0A%20%20%20%20%20%20%20%20docker%3A%2F%2Fdockerpull.org%2F%24%7BPAUSE_CONTAINER_TAG%7D%20docker-archive%3A%24%7BWORKDIR%7D%2Fpause-container.tar%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EThis%20should%20tell%20skopeo%20to%20use%20a%20Docker%20Registry%20mirror%20(dockerpull.org)%20instead%20of%20the%20default%20option.%20This%20should%20do%20the%20trick.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211314%22%20target%3D%22_blank%22%3E%40DRAVE%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20error%20that%20you%20are%20seeing%20refer%20to%20the%20following%20Yocto%20recipe%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-goldvip%2Fmeta-gvip%2Fblob%2Fdevelop%2Frecipes-containers%2Fk3s%2Fk3s_%2525.bbappend%23L42-L46%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-goldvip%2Fmeta-gvip%2Fblob%2Fdevelop%2Frecipes-containers%2Fk3s%2Fk3s_%2525.bbappend%23L42-L46%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMore%20specifically%2C%20to%20this%20part%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Edo_fetch_pause_container()%20%7B%0A%20%20%20%20rm%20-f%20%24%7BWORKDIR%7D%2Fpause-container.tar%0A%20%20%20%20skopeo%20--override-arch%20arm64%20copy%20--additional-tag%3D%22docker.io%2F%24%7BPAUSE_CONTAINER_TAG%7D%22%20%5C%0A%20%20%20%20%20%20%20%20docker%3A%2F%2F%24%7BPAUSE_CONTAINER_TAG%7D%20docker-archive%3A%24%7BWORKDIR%7D%2Fpause-container.tar%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EIt%20is%20attempting%20to%20use%20the%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcontainers%2Fskopeo%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESkopeo%3C%2FA%3E%20tool%20for%20copying%20the%20Docker%20image%20%3CEM%3Erancher%2Fmirrored-pause%3A3.6.%3C%2FEM%3E%20However%2C%20the%20address%20%3CA%20href%3D%22https%3A%2F%2Fregistry-1.docker.io%2Fv2%2F%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fregistry-1.docker.io%2Fv2%2F%3C%2FA%3E%20is%20blocked%20in%20China.%3C%2FP%3E%3CP%3EIf%20you%20have%20the%20option%20of%20using%20a%20VPN%20to%20fetch%20this%20file%2C%20this%20would%20be%20the%20easiest%20approach.%3C%2FP%3E%3CP%3EI%20will%20take%20a%20look%20and%20see%20if%20there%20is%20a%20way%20to%20manually%20bypass%20this%20step.%20If%20I%20find%20something%2C%20I%20will%20give%20you%20a%20feedback.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241130%22%20target%3D%22_blank%22%3E%40GuilhermeS32G%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20reply!%26nbsp%3BI%20put%20them%20in%20my%20downloads%20folder%20and%20that%20problem%20is%20solved.%26nbsp%3BI%20have%20a%20new%20problem.%26nbsp%3BProblems%20with%20compiling%20k3s%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_0-1733816525924.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_0-1733816525924.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315025i3762E811FFF18659%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DRAVE_0-1733816525924.png%22%20alt%3D%22DRAVE_0-1733816525924.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Elog%EF%BC%9A%3C%2FP%3E%3CP%3EInitialising%20tasks%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3CBR%20%2F%3ESstate%20summary%3A%20Wanted%2021%20Local%200%20Mirrors%200%20Missed%2021%20Current%203593%20(0%25%20match%2C%2099%25%20complete)%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3EERROR%3A%20k3s-v1.25.8%2Bk3s1-r0%20do_fetch_pause_container%3A%20ExecutionError('%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fbuild_s32g399ardb3goldvip%2Ftmp%2Fwoa53-crypto-fsl-linux%2Fk3s%2Fv1.25.8%2Bk3s1-r0%2Ftemp%2Frun.do_fetch_pause_container.32385'%2C%201%2C%20None%2C%20None)%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fbuild_s32g399ardb3goldvip%2Ftmp%2Fwork%2Fcortexa53-crypto-fsl-linux%2Fk3%2Bk3s1-r0%2Ftemp%2Flog.do_fetch_pause_container.32385%3CBR%20%2F%3ELog%20data%20follows%3A%3CBR%20%2F%3E%7C%20DEBUG%3A%20Executing%20shell%20function%20do_fetch_pause_container%3CBR%20%2F%3E%7C%20time%3D%222024-12-10T07%3A39%3A11Z%22%20level%3Dfatal%20msg%3D%22initializing%20source%20docker%3A%2F%2Francher%2Fmirrored-pause%3A3.6%3A%20pinging%20container%20registry%20registry-io%3A%20Get%20%5C%22%3CA%20href%3D%22https%3A%2F%2Fregistry-1.docker.io%2Fv2%2F%5C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fregistry-1.docker.io%2Fv2%2F%5C%3C%2FA%3E%22%3A%20dial%20tcp%3A%20lookup%20registry-1.docker.io%20on%2010.86.240.241%3A53%3A%20read%20udp%20172.17.0.8%3A40057-%26gt%3B10.86.24%20i%2Fo%20timeout%22%3CBR%20%2F%3E%7C%20WARNING%3A%20%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fbuild_s32g399ardb3goldvip%2Ftmp%2Fwork%2Fcortexa53-crypto-fsl-linux%2Fk3s%2Fv1.25.8%2Bk3s1-r0%2Ftemp%2Frun_pause_container.32385%3A164%20exit%201%20from%20'skopeo%20--override-arch%20arm64%20copy%20--additional-tag%3D%22docker.io%2Francher%2Fmirrored-pause%3A3.6%22%20docker%3A%2F%2Frrrored-pause%3A3.6%20docker-archive%3A%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fbuild_s32g399ardb3goldvip%2Ftmp%2Fwork%2Fcortexa53-crypto-fsl-linux%2Fk3s%2Fv1.-r0%2Fpause-container.tar'%3CBR%20%2F%3E%7C%20WARNING%3A%20Backtrace%20(BB%20generated%20script)%3A%3CBR%20%2F%3E%7C%20%231%3A%20do_fetch_pause_container%2C%20%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fbuild_s32g399ardb3goldvip%2Ftmp%2Fwork%2Fcortexa53-crypto-fsl-linux%2Fk8%2Bk3s1-r0%2Ftemp%2Frun.do_fetch_pause_container.32385%2C%20line%20164%3CBR%20%2F%3E%7C%20%232%3A%20main%2C%20%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fbuild_s32g399ardb3goldvip%2Ftmp%2Fwork%2Fcortexa53-crypto-fsl-linux%2Fk3s%2Fv1.25.8%2Bk3s1-r0%2Fto_fetch_pause_container.32385%2C%20line%20168%3CBR%20%2F%3EERROR%3A%20Task%20(%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fsources%2Fmeta-virtualization%2Frecipes-containers%2Fk3s%2Fk3s_git.bb%3Ado_fetch_pause_container)%20th%20exit%20code%20'1'%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%208504%20tasks%20of%20which%208498%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%3C%2FP%3E%3CP%3ESummary%3A%201%20task%20failed%3A%3CBR%20%2F%3E%2Fhome%2Fworkspace%2Fs32g%2Fnxp-yocto-goldvip%2Fsources%2Fmeta-virtualization%2Frecipes-containers%2Fk3s%2Fk3s_git.bb%3Ado_fetch_pause_container%3CBR%20%2F%3ESummary%3A%20There%20was%201%20ERROR%20message%2C%20returning%20a%20non-zero%20exit%20code.%3CBR%20%2F%3EBitbake%20failed%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3EDo%20I%20need%20a%20VPN%20to%20download%20these%20K3s%20files%3F%26nbsp%3BCould%20you%20please%20send%20me%20the%20relevant%20documents%20of%20k3s%3F%3CFONT%20color%3D%22%23000000%22%3E%20Thank%20you!%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211314%22%20target%3D%22_blank%22%3E%40DRAVE%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThese%20missing%20files%20can%20be%20downloaded%20through%20the%20Web%20Archive%20or%20through%20mirrors.%3C%2FP%3E%3CUL%3E%3CLI%3Exml-commons-resolver%3A%20%3CA%20href%3D%22https%3A%2F%2Fweb.archive.org%2Fweb%2F20220327083228%2Fhttp%3A%2F%2Farchive.apache.org%2Fdist%2Fxml%2Fcommons%2Fxml-commons-resolver-1.2.tar.gz%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elink%3C%2FA%3E%3C%2FLI%3E%3CLI%3Exalan%3A%20%3CA%20href%3D%22https%3A%2F%2Fweb.archive.org%2Fweb%2F20150906012423%2Fhttp%3A%2F%2Farchive.apache.org%2Fdist%2Fxml%2Fxalan-j%2Fxalan-j_2_7_1-src.tar.gz%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elink%3C%2FA%3E%26nbsp%3B%3C%2FLI%3E%3CLI%3Eavalon-framework-api%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FMontaVista-OpenSourceTechnology%2Fsource-mirror%2Fblob%2Fmaster%2Favalon-framework-api-4.3-src.tar.gz%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elink%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EAs%20you%20may%20need%20a%20VPN%20for%20downloading%20these%20files%2C%20I%20attached%20them%20to%20the%20reply.%3C%2FP%3E%3CP%3EOnce%20downloaded%2C%20place%20them%20in%20your%20Downloads%20folder.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3ENo%20errors%20are%20reported%20after%20I%20configure%20NXP_FIRMWARE_LOCAL_DIR%20according%20to%20your%20suggestions.%26nbsp%3BI%20have%20a%20new%20problem.%26nbsp%3BI%20can't%20seem%20to%20get%20%3CFONT%20color%3D%22%23FF0000%22%3Exml-commons-resolver1.1-native-1.2-r1%2C%20xalan-j-native-2.7.1-r2%3C%2FFONT%3E%2C%20and%20%3CFONT%20color%3D%22%23FF0000%22%3Eavalon-framework-api-native-4.3-r1%3C%2FFONT%3E.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_0-1733795466146.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_0-1733795466146.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314959iC15AD710C24CDD99%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DRAVE_0-1733795466146.png%22%20alt%3D%22DRAVE_0-1733795466146.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThe%20website%20is%20as%20follows%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Farchive.apache.org%2Fdist%2Fxml%2Fcommons%2Fxml-commons-resolver-1.2.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Farchive.apache.org%2Fdist%2Fxml%2Fcommons%2Fxml-commons-resolver-1.2.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Farchive.apache.org%2Fdist%2Fxml%2Fxalan-j%2Fxalan-j_2_7_1-src.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Farchive.apache.org%2Fdist%2Fxml%2Fxalan-j%2Fxalan-j_2_7_1-src.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Farchive.apache.org%2Fdist%2Fexcalibur%2Favalon-framework%2Fsource%2Favalon-framework-api-4.3-src.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Farchive.apache.org%2Fdist%2Fexcalibur%2Favalon-framework%2Fsource%2Favalon-framework-api-4.3-src.tar.gz%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20also%20couldn't%20get%20the%20file%20using%20Google%20Chrome%20under%20windows%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_1-1733795668218.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_1-1733795668218.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314960i3045C75C4D9C854A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DRAVE_1-1733795668218.png%22%20alt%3D%22DRAVE_1-1733795668218.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3EDo%20not%20have%20permission%20to%20access%20this%20resource%3F%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3ECan%20you%20help%20me%20find%20out%20why%3F%3CFONT%20color%3D%22%23000000%22%3E%20Thank%20you!%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Troubleshoot%20the%20GoldVIP%20setup%20on%20the%20S32G-VNP-RDB3%20demo%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211314%22%20target%3D%22_blank%22%3E%40DRAVE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EI%20suggest%20modify%20the%20local.conf%20with%20the%20following%20line%3A%3C%2FP%3E%0A%3CP%3ENXP_FIRMWARE_LOCAL_DIR%20%3D%20%22%2Fhome%2Fworkspace%2FS32G%22%3C%2FP%3E%0A%3CP%3EYou%20may%20edit%20it%20and%20retry%20the%20Yocto%20building.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
