S32G2 Linux LLCE debugfs interface
m_bez
I'm trying to set up LLCE filters to route some messages on can10 to can11, and route other messages to the host.
First, I would like to ask where the documentation for the debugfs interface is. There is an example in the S32G2_LinuxBSP_42.0_User_Manual.pdf, and modifying this allows the creation of filters between interfaces. However, I'm not sure how to create a filter that uses a mask or ID to send some traffic to the Linux host.
The file /sys/kernel/debug/llce_can_core/can_destinations/add/README refers to the LLCE Firmware User Guide. Where can I find this document, or perhaps some more examples of LLCE filter configurations?
carlos_o
Apologies for the misunderstanding here are some comments to improve the script that you share and some explanations.
1.  "echo 0x7FF > /sys/kernel/debug/llce_can_core/can_filters/add/can_mask_id" means that only standard frames are received. The CAN ID of the standard frame is 11 bits, so the can_mask_id is 0x7FF, which means that only the lower 11 bits are concerned when the mask matches. If it is an extended frame ID (29-bit ID), change 0x7FF to 0x1FFFFFFF. If you want to ignore some bits, fill them with 0, for example, 0x7F0 means the last 4 bits are ignored.
2.  "echo mask > /sys/kernel/debug/llce_can_core/can_filters/add/entry" The mask here is not the incoming parameter mask_id, but the configuration filter mode is mask match or exact match, so you cannot mistakenly assign mask as an incoming parameter.
3.  "0xe > /sys/kernel/debug/llce_can_core/can_filters/add/tag" When configuring the basic filter, the tag value is strongly related to the channel. Here, 0xe corresponds to channel 14. You use channel 11, so it should be changed to "0xb > /sys/kernel/debug/llce_can_core/can_filters/add/tag"
carlos_o
m_bez
Hey Carlos, thanks for your reply. It took me some time to get back to you, because setting the tags correctly was the last big hurdle and I've made quite a bit of progress since. I've run into a new issue, but I'll open a new thread for that, since this one is getting quite long and contains too many topics already. Thanks for your help.
m_bez
Hey, @carlos_o
Good news, we are making some progress. When I set up the tag to correspond to the interface number, the behavior changes.
The filter now _almost_ behaves as expected, I just get empty CAN frames when the mask matches. For clarity I've added a complete log with ###comments to explain the testing.
1) At boot, the host receives data on both llcecan10 and llcecan11, regardless of canID
root@s32g274a-n4c0a53:~# candump any,0:0,#FFFFFFFF
llcecan11 1FFFFFFF [4] DE AD BE EF
llcecan10 00000000 [4] DE AD BE EF
2) Next, two filters are set up, to use 0x00000000 and 0x 1FFFFFFF as masks respectively.
11 enabled 0x00000000 0x00000000 0x000b 0x0010 524 4 mask short |
10 enabled 0x1fffffff 0x00000000 0x000a 0x0010 525 5 mask short |
3) the llcecan interfaces do report receiving _something_ when frames that match the masks are sent, but the contents are not received for some reason
llcecan10 000 [0]
llcecan11 000 [0]
What could be the cause of these frames being displayed as empty? I've `cat`'ed anything that i thought might be relevant in the attached log.
To summarize, the filter now seems to be matching on the mask correctly, but the frames received by the host contain no data.
carlos_o
Hi @m_bez,
The llcecan10 and llcecan11 are initialized to not support the CANFD type, so the tags in the script need to be changed to 0x10a and 0x10b. If the channel supports CANFD type, the tag needs to be changed to 0xa and 0xb.
carlos_o
Hi @m_bez,
reviewing the script, you attached they are some values that I think you need to review, it is the can_dest, can_mask_id and msg_id. What are you objective to do with those values?
m_bez
Hey Carlos
> can_dest
This was taken from the provided example to create a filter that uses the host as destination. Usually this value refers to a destination created in `/sys/kernel/debug/llce_can_core/can_destinations/` , but in this case, no such destination exists. In the provided example, 0xFF was used when no destination existed, and I used the same.
> can_mask_id
This is the mask used to filter CAD emesages by ID, the default filters all used 0x00000000, so I used the same, to create a filter that passes all traffic to the host. I did also try using 0xFFFFFFFF, in case the mask works differently, but this dod not affect the behavior.
> msg_id
It is my understanding that this value is only used when creating an "exact" filter, and I expect this value to be ignored. I used 0x00000000, and did test to see it the filter behaves differently if ite receives a message with CAN identifier 0x00000000, but these messages are also not received by the host.
carlos_o
Hi @m_bez,
Your understanding of msg_id is correct.
can_mask_id as 0x00000000 is correct for the test you are doing to allow all id to pass.
How are you testing that the host is receiving or not the CAN msg?
m_bez
Hey @carlos_o
two ways. First, by monitoring the output of
`candump any,0:0,#FFFFFFFF`
Second, by monitoring the contents of
`/sys/class/net/llcecan11/statistics/`
With a can interface sending packets to llcecan11. I confirm that both methods of monitoring traffic indicate receiving traffic, and then I create the filter, and then it stops receiving traffic.
carlos_o
Hi @m_bez
thanks for sharing the details, I'm reviewing with the internal team the possibles root causes of this issue. We appreciate your patience.
carlos_o
Hi @m_bez,
Let me review with the internal team what can be the root causes of this issue. This may take a longer response time. I'll come ASAP with further information.
carlos_o
Hi @m_bez,
When you install the LLCE Driver + Firmware package, you can locate the LLCE Firmware User Guide at
C:\NXP\S32G_LLCE_1_0_9\firmware\llce_interface\doc
if you use the default install location.
m_bez
Great, got it. Thanks! Will see if I can get the debugFS interface figured out from that.
carlos_o
Let me know if you have more questions.
%3CLINGO-SUB%20id%3D%22lingo-sub-2037201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2037201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20trying%20to%20set%20up%20LLCE%20filters%20to%20route%20some%20messages%20on%20can10%20to%20can11%2C%20and%20route%20other%20messages%20to%20the%20host.%3C%2FP%3E%3CP%3EFirst%2C%20I%20would%20like%20to%20ask%20where%20the%20documentation%20for%20the%20debugfs%20interface%20is.%20There%20is%20an%20example%20in%20the%20S32G2_LinuxBSP_42.0_User_Manual.pdf%2C%20and%20modifying%20this%20allows%20the%20creation%20of%20filters%20between%20interfaces.%20However%2C%20I'm%20not%20sure%20how%20to%20create%20a%20filter%20that%20uses%20a%20mask%20or%20ID%20to%20send%20some%20traffic%20to%20the%20Linux%20host.%3C%2FP%3E%3CP%3EThe%20file%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2Fadd%2FREADME%20refers%20to%20the%20LLCE%20Firmware%20User%20Guide.%20Where%20can%20I%20find%20this%20document%2C%20or%20perhaps%20some%20more%20examples%20of%20LLCE%20filter%20configurations%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20Carlos%2C%20thanks%20for%20your%20reply.%20It%20took%20me%20some%20time%20to%20get%20back%20to%20you%2C%20because%20setting%20the%20tags%20correctly%20was%20the%20last%20big%20hurdle%20and%20I've%20made%20quite%20a%20bit%20of%20progress%20since.%20I've%20run%20into%20a%20new%20issue%2C%20but%20I'll%20open%20a%20new%20thread%20for%20that%2C%20since%20this%20one%20is%20getting%20quite%20long%20and%20contains%20too%20many%20topics%20already.%20Thanks%20for%20your%20help.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20llcecan10%20and%20llcecan11%20are%20initialized%20to%20not%20support%20the%20CANFD%20type%2C%20so%20the%20tags%20in%20the%20script%20need%20to%20be%20changed%20to%200x10a%20and%200x10b.%20If%20the%20channel%20supports%20CANFD%20type%2C%20the%20tag%20needs%20to%20be%20changed%20to%200xa%20and%200xb.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EGood%20news%2C%20we%20are%20making%20some%20progress.%20When%20I%20set%20up%20the%20tag%20to%20correspond%20to%20the%20interface%20number%2C%20the%20behavior%20changes.%3CBR%20%2F%3EThe%20filter%20now%20_almost_%20behaves%20as%20expected%2C%20I%20just%20get%20empty%20CAN%20frames%20when%20the%20mask%20matches.%20For%20clarity%20I've%20added%20a%20complete%20log%20with%20%23%23%23comments%20to%20explain%20the%20testing.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E1)%20At%20boot%2C%20the%20host%20receives%20data%20on%20both%20llcecan10%20and%20llcecan11%2C%20regardless%20of%20canID%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3Eroot%40s32g274a-n4c0a53%3A~%23%20candump%20any%2C0%3A0%2C%23FFFFFFFF%3CBR%20%2F%3Ellcecan11%201FFFFFFF%20%5B4%5D%20DE%20AD%20BE%20EF%3CBR%20%2F%3Ellcecan10%2000000000%20%5B4%5D%20DE%20AD%20BE%20EF%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E2)%20Next%2C%20two%20filters%20are%20set%20up%2C%20to%20use%200x00000000%20and%200x%201FFFFFFF%20as%20masks%20respectively.%3CBR%20%2F%3E%60%60%60%3C%2FP%3E%3CP%3E11%20enabled%200x00000000%200x00000000%200x000b%200x0010%20524%204%20mask%20short%20%7C%3C%2FP%3E%3CP%3E10%20enabled%200x1fffffff%200x00000000%200x000a%200x0010%20525%205%20mask%20short%20%7C%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E3)%20the%20llcecan%20interfaces%20do%20report%20receiving%20_something_%20when%20frames%20that%20match%20the%20masks%20are%20sent%2C%20but%20the%20contents%20are%20not%20received%20for%20some%20reason%3C%2FP%3E%3CP%3E%60%60%60%3CBR%20%2F%3Eroot%40s32g274a-n4c0a53%3A~%23%20candump%20any%2C0%3A0%2C%23FFFFFFFF%3CBR%20%2F%3Ellcecan10%20000%20%5B0%5D%3CBR%20%2F%3Ellcecan11%20000%20%5B0%5D%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3EWhat%20could%20be%20the%20cause%20of%20these%20frames%20being%20displayed%20as%20empty%3F%20I've%20%60cat%60'ed%20anything%20that%20i%20thought%20might%20be%20relevant%20in%20the%20attached%20log.%3CBR%20%2F%3E%3CBR%20%2F%3ETo%20summarize%2C%20the%20filter%20now%20seems%20to%20be%20matching%20on%20the%20mask%20correctly%2C%20but%20the%20frames%20received%20by%20the%20host%20contain%20no%20data.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EApologies%20for%20the%20misunderstanding%20here%20are%20some%20comments%20to%20improve%20the%20script%20that%20you%20share%20and%20some%20explanations.%3C%2FP%3E%0A%3CP%3E1.%20%26nbsp%3B%22echo%200x7FF%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_mask_id%22%20means%20that%20only%20standard%20frames%20are%20received.%20The%20CAN%20ID%20of%20the%20standard%20frame%20is%2011%20bits%2C%20so%20the%20can_mask_id%20is%200x7FF%2C%20which%20means%20that%20only%20the%20lower%2011%20bits%20are%20concerned%20when%20the%20mask%20matches.%20If%20it%20is%20an%20extended%20frame%20ID%20(29-bit%20ID)%2C%20change%200x7FF%20to%200x1FFFFFFF.%20If%20you%20want%20to%20ignore%20some%20bits%2C%20fill%20them%20with%200%2C%20for%20example%2C%200x7F0%20means%20the%20last%204%20bits%20are%20ignored.%3C%2FP%3E%0A%3CP%3E2.%20%26nbsp%3B%22echo%20mask%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fentry%22%20The%20mask%20here%20is%20not%20the%20incoming%20parameter%20mask_id%2C%20but%20the%20configuration%20filter%20mode%20is%20mask%20match%20or%20exact%20match%2C%20so%20you%20cannot%20mistakenly%20assign%20mask%20as%20an%20incoming%20parameter.%3C%2FP%3E%0A%3CP%3E3.%20%26nbsp%3B%220xe%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Ftag%22%20When%20configuring%20the%20basic%20filter%2C%20the%20tag%20value%20is%20strongly%20related%20to%20the%20channel.%20Here%2C%200xe%20corresponds%20to%20channel%2014.%20You%20use%20channel%2011%2C%20so%20it%20should%20be%20changed%20to%20%220xb%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Ftag%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI've%20described%20the%20behavior%20when%20I%20use%20a%20different%20destination%20already%3A%3C%2FP%3E%3CP%3E%26gt%3B%20The%20filter%20and%20host%20are%20set%20up%20as%20follows%3A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Ehw_ctrl%20status%20can_mask_id%20msg_id%20tag%20mb_count%20addr%20rx_intf%20entry%20mb_type%20%7C%20opt_auth%20opt_host%20logging%20opt_custom%20can_dest%3CBR%20%2F%3E10%20disabled%200x00000000%200x00000000%200x0000%200x0010%20524%205%20mask%20short%20%7C%20disabled%20enabled%20disabled%20disabled%200%3CBR%20%2F%3Eid%20routing_opts%20can_id_remap%20ch_list%3CBR%20%2F%3E0%200x00000000%200x00000000%2011%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%26gt%3BIf%20I%20send%20a%20single%20message%20to%20can10%2C%20it%20gets%20routed%20to%20can%2011%2C%20as%20well%20as%20the%20host.%20Messages%20after%20that%20do%20not%20get%20routed.%20After%20I've%20sent%2016%20messages%20without%20one%20being%20delivered%2C%20the%20can%20interface%20on%20the%20host%20starts%20reporting%20a%20bus%20error%20every%20time%20I%20send%20a%20message.%3C%2FP%3E%3CP%3ETo%20put%20'HIF'%20as%20destination%20is%20unclear%20to%20me.%20I'm%20unable%20to%20write%20%60HIF%60%20into%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_dest%3CBR%20%2F%3E-sh%3A%20echo%3A%20write%20error%3A%20Invalid%20argument%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20notice%20as%20you%20say%20in%20this%20thread%20that%20the%20filter%20that%20you%20are%20setting%20does%20not%20have%20another%20destination%2C%20why%20you%20did%20not%20put%20HIF%20(host%20interface)%20as%20destination%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-02-27%20181100.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-02-27%20181100.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F326143i1397CEDD1C9A2659%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-02-27%20181100.png%22%20alt%3D%22Screenshot%202025-02-27%20181100.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202025-02-27%20181100.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIn%20this%20case%20the%20error%20can%20be%20because%20the%20can%20destination%20you%20are%20setting%20is%20not%20initialized.%20Another%20option%20can%20be%20initializing%20another%20llce%20can%20interface%20and%20put%20it%20as%20destination%20of%20the%20filter.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%2C%20sure%20thing!%3C%2FP%3E%3CP%3E1)%20modify%20the%20llcecan11%20line%20in%20%60%2Fetc%2Fllce_config%2Fllce_init.sh%60%20to%20be%20%60ip%20link%20set%20up%20llcecan11%20type%20can%20bitrate%20500000%60%3CBR%20%2F%3E2)%20With%20another%20CAN%20device%2C%20connect%20to%20llce11.%20I'm%20using%20a%20laptop%20with%20ubuntu%2024.04%20and%20a%20PEAK-USB%20device.%3CBR%20%2F%3E3)%20From%20the%20other%20device%2C%20send%20some%20can%20traffic%20to%20the%20S32%20device.%20In%20my%20case%2C%20the%20commands%20on%20the%20laptop%20are%3A%3CBR%20%2F%3E%60sudo%20ip%20link%20set%20up%20can1%20up%20type%20can%20bitrate%20500000%60%3CBR%20%2F%3E%60cansend%20can0%20000%23deadbeef%60%3CBR%20%2F%3E4)%20on%20the%20S32%2C%20confirm%20that%20the%20can%20messages%20are%20being%20received%20using%20%60candump%20any%2C0%3A0%2C%23FFFFFFFF%60%3CBR%20%2F%3E5)%20on%20the%20S32%2C%20run%20the%20script%20called%20%60setup_llce_NXP_Example.sh%60.%20It's%20the%20same%20as%20one%20attached%20to%20an%20earlier%20post%20in%20this%20discussion%3CBR%20%2F%3E6)%20inspect%20%60%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Flist%60%20to%20see%20that%20the%20original%20filter%20on%20llcecan11%20was%20disabled%2C%20and%20a%20new%2C%20identical%20filter%20was%20created%20by%20the%20script.%3CBR%20%2F%3E7)%20After%20running%20the%20script%2C%20do%20%60%60candump%20any%2C0%3A0%2C%23FFFFFFFF%60%60%20again.%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20from%20the%20laptop%2C%20send%20some%20more%20CAN%20traffic%3CBR%20%2F%3E9)%20On%20my%20device%20the%20CAN%20traffic%20is%20not%20received%20after%20running%20the%20script%2C%20while%20I%20expect%20it%20to%20be.%3CBR%20%2F%3EI'm%20attaching%20the%20script%20again%2C%20as%20well%20as%20a%20screenshot%20of%20the%20two%20terminal%20sessions%2C%20for%20clarity.%20The%20top%20terminal%20is%20the%20laptop%2C%20and%20the%20bottom%20one%20is%20an%20SSH%20session%20to%20the%20S32%20device.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20help%20me%20with%20a%20step-by-step%20to%20reproduce%20the%20issue%3F%3C%2FP%3E%0A%3CP%3EThis%20to%20the%20objective%20to%20reproduce%20the%20issue%20at%20my%20end.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2050577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3Etwo%20ways.%20First%2C%20by%20monitoring%20the%20output%20of%3CBR%20%2F%3E%60candump%20any%2C0%3A0%2C%23FFFFFFFF%60%3CBR%20%2F%3ESecond%2C%20by%20monitoring%20the%20contents%20of%3CBR%20%2F%3E%60%2Fsys%2Fclass%2Fnet%2Fllcecan11%2Fstatistics%2F%60%3CBR%20%2F%3E%3CBR%20%2F%3EWith%20a%20can%20interface%20sending%20packets%20to%20llcecan11.%20I%20confirm%20that%20both%20methods%20of%20monitoring%20traffic%20indicate%20receiving%20traffic%2C%20and%20then%20I%20create%20the%20filter%2C%20and%20then%20it%20stops%20receiving%20traffic.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2050292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EYour%20understanding%20of%20msg_id%20is%20correct.%3C%2FP%3E%0A%3CP%3Ecan_mask_id%20as%200x00000000%20is%20correct%20for%20the%20test%20you%20are%20doing%20to%20allow%20all%20id%20to%20pass.%3C%2FP%3E%0A%3CP%3EHow%20are%20you%20testing%20that%20the%20host%20is%20receiving%20or%20not%20the%20CAN%20msg%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2049690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2049690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20Carlos%3CBR%20%2F%3E%26gt%3B%20can_dest%3C%2FP%3E%3CP%3EThis%20was%20taken%20from%20the%20provided%20example%20to%20create%20a%20filter%20that%20uses%20the%20host%20as%20destination.%20Usually%20this%20value%20refers%20to%20a%20destination%20created%20in%20%60%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2F%60%20%2C%20but%20in%20this%20case%2C%20no%20such%20destination%20exists.%20In%20the%20provided%20example%2C%200xFF%20was%20used%20when%20no%20destination%20existed%2C%20and%20I%20used%20the%20same.%3CBR%20%2F%3E%26gt%3B%20can_mask_id%3C%2FP%3E%3CP%3EThis%20is%20the%20mask%20used%20to%20filter%20CAD%20emesages%20by%20ID%2C%20the%20default%20filters%20all%20used%200x00000000%2C%20so%20I%20used%20the%20same%2C%20to%20create%20a%20filter%20that%20passes%20all%20traffic%20to%20the%20host.%20I%20did%20also%20try%20using%200xFFFFFFFF%2C%20in%20case%20the%20mask%20works%20differently%2C%20but%20this%20dod%20not%20affect%20the%20behavior.%3CBR%20%2F%3E%26gt%3B%20msg_id%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EIt%20is%20my%20understanding%20that%20this%20value%20is%20only%20used%20when%20creating%20an%20%22exact%22%20filter%2C%20and%20I%20expect%20this%20value%20to%20be%20ignored.%20I%20used%200x00000000%2C%20and%20did%20test%20to%20see%20it%20the%20filter%20behaves%20differently%20if%20ite%20receives%20a%20message%20with%20CAN%20identifier%200x00000000%2C%20but%20these%20messages%20are%20also%20not%20received%20by%20the%20host.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2049292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2049292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3Ereviewing%20the%20script%2C%20you%20attached%20they%20are%20some%20values%20that%20I%20think%20you%20need%20to%20review%2C%20it%20is%20the%20can_dest%2C%20can_mask_id%20and%20msg_id.%20What%20are%20you%20objective%20to%20do%20with%20those%20values%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%20%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI'm%20not%20getting%20an%20error%20per%20s%C3%A9%2C%20the%20llececan%20interface%20just%20stops%20receiving%20packets%20after%20I've%20created%20the%20filter.%20The%20script%20I've%20attached%20runs%20fine%20without%20any%20errors%2C%20but%20then%20the%20output%20of%3CBR%20%2F%3E%22candump%20any%2C0%3A0%2C%23FFFFFFFF%22%20gives%20no%20output%2C%20whereas%20before%20running%20the%20script%20it%20was%20printing%20whatever%20was%20on%20the%20bus.%3CBR%20%2F%3EI%20specifically%20checked%20for%20network%20errors%20in%20%60%2Fsys%2Fclass%2Fnet%2Fllcecan10%2Fstatistics%2F%60%2C%20but%20there%20are%20none.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3Egreat%20to%20hear%20that%20you%20were%20able%20to%20configure%20the%20filter.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20a%20log%20file%20with%20an%20example%20of%20the%20error%20you%20are%20getting%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20very%20much%2C%20this%20is%20very%20helpful%2C%20I'm%20happy%20to%20report%20that%20the%20filter%20is%20added%20to%20the%20list%20as%20expected.%20However%2C%20the%20filter%20doesn't%20work.%20As%20a%20sanity%20check%2C%20I've%20created%20a%20filter%20that%20exactly%20replicates%20the%20default%20one%2C%20with%20a%20mask%20of%200x000000.%20When%20I%20do%20this%2C%20I%20get%20traffic%20on%20the%20interface%20before%20I%20recreate%20the%20filter%2C%20but%20nothing%20after.%20I%20don't%20see%20any%20values%20increasing%20in%20%60%3CSPAN%3E%2Fsys%2Fclass%2Fnet%2Fllcecan10%2Fstatistics%2F%3C%2FSPAN%3E%60%20that%20would%20indicate%20an%20error.%3CBR%20%2F%3EDue%20to%20hardware%20constraints%2C%20I'm%20using%20different%20interfaces%20(llcecan10%20and%20llcecan11)%2C%20and%20normal%20CAN%20in%20stead%20of%20canFD%2C%20so%20I've%20needed%20to%20change%20the%20example%20slightly.%20I'm%20attaching%20the%20script%20I'm%20using%20to%20test%20this.%20Could%20you%20please%20check%20if%20I'm%20making%20some%20mistake%2C%20or%20if%20the%20behavior%20is%20indeed%20unexpected.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20also%20tried%20to%20create%20an%20exact%20matching%20filter%2C%20for%20address%200x77%2C%20from%20the%20example%20in%20the%20documentation%2C%20but%20the%20interface%20just%20stops%20receiving%20communication.%3CBR%20%2F%3E%3CBR%20%2F%3Ethe%20interface%20is%20up%20when%20I%20check%20%60ip%20link%20show%60%2C%20and%20if%20I%20do%20%60cansend%20000%23AABBCCDD%60%20the%20interface%20is%20able%20to%20send%20frames%20correctly.%20It%20just%20stops%20receiving%20frames%20once%20I%20create%20the%20basic%20filter%20that%20is%20exactly%20the%20same%20as%20the%20default%20filter%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%60%60%60%3C%2FP%3E%3CP%3Eroot%40s32g274a-n4c0a53%3A~%23%20cat%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Flist%3CBR%20%2F%3Ehw_ctrl%20status%20can_mask_id%20msg_id%20tag%20mb_count%20addr%20rx_intf%20entry%20mb_type%20%7C%20opt_auth%20opt_host%20logging%20opt_custom%20can_dest%3CBR%20%2F%3E0%20enabled%200x00000000%200x00000000%200x0000%200x0010%20512%2015%20mask%20long%20%7C%3CBR%20%2F%3E%5B...%5D%3CBR%20%2F%3E8%20enabled%200x00000000%200x00000000%200x0008%200x0010%20520%207%20mask%20long%20%7C%3CBR%20%2F%3E9%20enabled%200x00000000%200x00000000%200x0009%200x0010%20521%206%20mask%20long%20%7C%3CBR%20%2F%3E10%20enabled%200x00000000%200x00000000%200x010a%200x0010%20522%205%20mask%20short%20%7C%3CBR%20%2F%3E11%20disabled%200x00000000%200x00000000%200x010b%200x0010%20523%204%20mask%20short%20%7C%3CBR%20%2F%3E11%20enabled%200x00000000%200x00000000%200x000e%200x0010%20524%204%20mask%20short%20%7C%3C%2FP%3E%3CP%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3EAnother%20question%20about%20the%20example%2C%20could%20you%20please%20explain%20the%200x7F0%20values%20that%20get%20written%20to%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_mask_id%20for%20both%20filters%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20Internal%20team%20shares%20the%20following%20example%20of%20the%20complete%20configuration%20of%20a%20filter%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%3E%23%20llcecan%20link%20up%0Aip%20link%20set%20up%20llcecan14%20type%20can%20bitrate%20500000%20dbitrate%205000000%20fd%20on%0Aip%20link%20set%20up%20llcecan15%20type%20can%20bitrate%20500000%20dbitrate%205000000%20fd%20on%0A%0A%23%20disable%20current%20basic%20filter%0Aecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Fstatus%0Aecho%20512%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Faddr%0Aecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Fexecute%0Aecho%20513%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Faddr%0Aecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Fexecute%0A%0A%23%20llcecan14%20basic%20filte%0A%0Aecho%200xFF%20%26gt%3B%20%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_dest%0Aecho%200x7F0%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_mask_id%0Aecho%20mask%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fentry%0Aecho%2014%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fhw_ctrl%0Aecho%200xe%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Ftag%0Aecho%200x10%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmb_count%0Aecho%20long%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmb_type%0Aecho%200x540%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmsg_id%0Aecho%20enabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fstatus%0Aecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fexecute%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSPAN%3EAfter%20executing%20the%20above%20command%2C%20a%20filter%20as%20shown%20below%20will%20be%20created.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carlos_o_0-1739988050013.png%22%20style%3D%22width%3A%20584px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1739988050013.png%22%20style%3D%22width%3A%20584px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324800i2B609C0C93FE10D0%2Fimage-dimensions%2F584x40%3Fv%3Dv2%22%20width%3D%22584%22%20height%3D%2240%22%20role%3D%22button%22%20title%3D%22carlos_o_0-1739988050013.png%22%20alt%3D%22carlos_o_0-1739988050013.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1739988050013.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%3E%23%20Create%20a%20destination%20to%20be%20used%20for%20LLCE%20CAN14%E2%86%92LLCE%20CAN15%20route.%0Aecho%200x0%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2Fadd%2Fcan_id_remap%0Aecho%2015%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2Fadd%2Fch_list%0Aecho%200x1%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2Fadd%2Frouting_opts%0Aecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2Fadd%2Fexecute%0Acat%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_destinations%2Fadd%2Fexecute%20%26gt%3B%20%5C%0A%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_dest%0Aecho%200x7F0%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_mask_id%0Aecho%20mask%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fentry%0Aecho%2014%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fhw_ctrl%0Aecho%200xe%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Ftag%0Aecho%200x10%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmb_count%0Aecho%20long%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmb_type%0Aecho%200x530%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmsg_id%0Aecho%20enabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fstatus%0Aecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fopt_auth%0Aecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fopt_custom%0Aecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fopt_host%0Aecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Flogging%0Aecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fexecute%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSPAN%3EAfter%20executing%20the%20above%20command%2C%20an%20additional%20filter%20will%20be%20created%20as%20shown%20in%20the%20figure%20below.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carlos_o_1-1739988082656.png%22%20style%3D%22width%3A%20588px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_1-1739988082656.png%22%20style%3D%22width%3A%20588px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324801i0BFBBFF3284F988F%2Fimage-dimensions%2F588x47%3Fv%3Dv2%22%20width%3D%22588%22%20height%3D%2247%22%20role%3D%22button%22%20title%3D%22carlos_o_1-1739988082656.png%22%20alt%3D%22carlos_o_1-1739988082656.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_1-1739988082656.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EYou%20need%20to%20disable%20the%20unused%20filters%20in%20the%20filter%20list%20to%20prevent%20interference%20between%20filters.%20After%20testing%2C%20the%20first%20filter%20will%20receive%20IDs%20between%200x540~0x54F%20to%20the%20host%2C%20and%20route%20IDs%20between%200x530~0x53F%20to%20llcecan15.%20If%20you%20need%20a%20CAN%20frame%20to%20be%20received%20by%20the%20host%20and%20routed%20to%20another%20channel%20at%20the%20same%20time%2C%20opt_host%20enable%20of%20the%20corresponding%20filter%20is%20required.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ethanks%20for%20sharing%20the%20details%2C%20I'm%20reviewing%20with%20the%20internal%20team%20the%20possibles%20root%20causes%20of%20this%20issue.%20We%20appreciate%20your%20patience.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESome%20more%20info%20that%20might%20be%20of%20use%2C%20the%20errors%20that%20get%20generated%20increment%20the%20values%20in%3CBR%20%2F%3E%2Fsys%2Fclass%2Fnet%2Fllcecan10%2Fstatistics%2Frx_dropped%3CBR%20%2F%3Eand%3CBR%20%2F%3E%2Fsys%2Fclass%2Fnet%2Fllcecan10%2Fstatistics%2Frx_errors%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20the%20two%20llcecan%20interfaces%20in%20question.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%2C%20if%20I%20set%20the%20filter%20explicitly%20to%20enabled%20before%20executing%2C%20I%20get%20a%20permission%20error%20trying%20to%20write%20to%20the%20file%3CBR%20%2F%3E%60%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fset_status%3A%20Permission%20denied%60%3CBR%20%2F%3EIf%20I%20list%20the%20filters%20after%2C%20they%20seem%20to%20be%20enumerated%20as%20enabled%20in%20any%20case%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Eroot%40s32g274a-n4c0a53%3A~%23%20cat%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Flist%3CBR%20%2F%3Ehw_ctrl%20status%20can_mask_id%20msg_id%20tag%20mb_count%20addr%20rx_intf%20entry%20mb_type%20%7C%20opt_auth%20opt_host%3CBR%20%2F%3Elogging%20opt_custom%20can_dest%3CBR%20%2F%3E0%20enabled%200x00000000%200x00000000%200x0000%200x0010%20512%2015%20mask%20long%20%7C%3C%2FP%3E%3CP%3E1%20enabled%200x00000000%200x00000000%200x0001%200x0010%20513%2014%20mask%20long%20%7C%3C%2FP%3E%3CP%3E2%20enabled%200x00000000%200x00000000%200x0002%200x0010%20514%2013%20mask%20long%20%7C%3CBR%20%2F%3E3%20enabled%200x00000000%200x00000000%200x0003%200x0010%20515%2012%20mask%20long%20%7C%3CBR%20%2F%3E4%20enabled%200x00000000%200x00000000%200x0004%200x0010%20516%2011%20mask%20long%20%7C%3CBR%20%2F%3E5%20enabled%200x00000000%200x00000000%200x0005%200x0010%20517%2010%20mask%20long%20%7C%3CBR%20%2F%3E6%20enabled%200x00000000%200x00000000%200x0006%200x0010%20518%209%20mask%20long%20%7C%3CBR%20%2F%3E7%20enabled%200x00000000%200x00000000%200x0007%200x0010%20519%208%20mask%20long%20%7C%3CBR%20%2F%3E8%20enabled%200x00000000%200x00000000%200x0008%200x0010%20520%207%20mask%20long%20%7C%3CBR%20%2F%3E9%20enabled%200x00000000%200x00000000%200x0009%200x0010%20521%206%20mask%20long%20%7C%3CBR%20%2F%3E10%20disabled%200x00000000%200x00000000%200x010a%200x0010%20522%205%20mask%20short%20%7C%3CBR%20%2F%3E11%20disabled%200x00000000%200x00000000%200x010b%200x0010%20523%204%20mask%20short%20%7C%3CBR%20%2F%3E10%20enabled%200x00000000%200x00000000%200x0000%200x0010%20524%205%20mask%20short%20%7C%20disabled%20enabled%20disabled%20disabled%200%3CBR%20%2F%3E11%20enabled%200x00000000%200x00000000%200x0000%200x0010%20525%204%20mask%20short%20%7C%20disabled%20enabled%20disabled%20disabled%201%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3ESetting%20the%20status%20works%2C%20if%20I%20write%2C%20the%20address%2C%20%22disabled%22%20and%20execute%20into%20the%20respective%20files%20in%20%60%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%60%2C%20then%20the%20status%20visibly%20changes%20form%20'enabled'%20to%20'disabled'%20when%20I%20list%20the%20filters.%3C%2FP%3E%3CP%3EEnabling%20and%20disabling%20the%20filter%20doesn't%20seem%20to%20affect%20the%20behvior%20initially.%20It%20still%20only%20forwards%20a%20single%20message%20and%20reports%20bus%20errors%20after%2016%20messages.%20Once%20it%20starts%20reporting%20bus%20errors%2C%20disabling%20and%20enabling%20the%20filter%20doesn't%20make%20it%20forward%20a%20single%20message%20again.%20That%20only%20happens%20if%20I%20reboot%20and%20reconfigure%20the%20filter.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2045681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIt%20seems%20like%20the%20filter%20status%20of%20your%20filter%20is%20disable.%20Could%20you%20please%20enable%20it%20with%20%22echo%20enabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fstatus%22%3F%3C%2FP%3E%0A%3CP%3ERetry%20to%20send%20the%20data%20after%20that%20and%20let%20me%20know%20the%20results.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2043668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2043668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ELet%20me%20review%20with%20the%20internal%20team%20what%20can%20be%20the%20root%20causes%20of%20this%20issue.%20This%20may%20take%20a%20longer%20response%20time.%20I'll%20come%20ASAP%20with%20further%20information.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2043210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2043210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20response.%20However%2C%20setting%20opt_host%20to%20%22enabled%22%20causes%20unexpected%20behavior%20as%20described%20earlier.%20Specifically%2C%20when%20opt_host%20is%20enabled%2C%20the%20first%20message%20behaves%20as%20expected%2C%20but%20subsequent%20messages%20do%20not%20get%20forwarded%2C%20and%20after%2016%20messages%2C%20the%20CAN%20interface%20on%20the%20host%20starts%20reporting%20bus%20errors.%3C%2FP%3E%3CP%3ECould%20you%20provide%20more%20detailed%20guidance%20on%20how%20to%20configure%20the%20filter%20to%20communicate%20with%20the%20host%20without%20causing%20these%20issues%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EQ%3A%26nbsp%3BTee%20example%20doesn't%20include%20the%20creation%20of%20destinations%2C%20does%20this%20still%20need%20to%20happen%3F%20or%20is%20destination%200xFF%20created%20by%20default%3F%3C%2FP%3E%0A%3CP%3EA%3A%20Yes%2C%20you%20still%20need%20to%20create%20a%20destination.%3C%2FP%3E%0A%3CP%3EQ%3A%26nbsp%3BThe%20value%20of%20the%20mask_id%20(0x7F)%20doesn't%20make%20sense%20to%20me.%20How%20does%20it%20relate%20to%20the%20addresses%20being%20filtered%3F%20All%20other%20parameters%20in%20the%20example%20make%20sense%20to%20me%2C%20and%20are%20already%20how%20I%20configure%20the%20filters%2C%20but%20it%20has%20no%20host%20communication.%3C%2FP%3E%0A%3CP%3EA%3A%20This%20mask_id%20is%20only%20an%20example%20and%20work%20as%20if%20you%20put%20a%20mask%20id%20in%20a%20CAN%20communication%20to%20take%20some%20action%20when%20a%20msg%20arrive%20with%20some%20id%20that%20pass%20the%20mask.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAlso%2C%20to%20enable%20the%20communication%20with%20the%20host%20you%20only%20need%20to%20set%20the%20opt_host%20config%20to%20%22enable%22%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAll%20the%20subdirectories%20at%20the%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2F%20have%20a%20README%20file%20that%20explain%20the%20possible%20configurations.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2041501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2041501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%26gt%3B%20The%20example%20only%20is%20for%20reference%3CBR%20%2F%3ETee%20example%20doesn't%20include%20the%20creation%20of%20destinations%2C%20does%20this%20still%20need%20to%20happen%3F%20or%20is%20destination%200xFF%20created%20by%20default%3F%3CBR%20%2F%3E%26gt%3B%26nbsp%3Blet%20me%20know%20the%20results%3CBR%20%2F%3EThe%20value%20of%20the%20mask_id%20(0x7F)%20doesn't%20make%20sense%20to%20me.%20How%20does%20it%20relate%20to%20the%20addresses%20being%20filtered%3F%20All%20other%20parameters%20in%20the%20example%20make%20sense%20to%20me%2C%20and%20are%20already%20how%20I%20configure%20the%20filters%2C%20but%20it%20has%20no%20host%20communication.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2041104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2041104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20example%20only%20is%20for%20reference%20to%20how%20to%20configure%20the%20filters.%3C%2FP%3E%0A%3CP%3EThanks%20for%20clarifying%20your%20goal%20with%20the%20filters%2C%20let%20me%20know%20the%20results%20you%20get%20and%20if%20it%20solves%20the%20problem%20with%20the%20bus%20error%20msg.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%20%2C%20thanks%20for%20the%20help.%3CBR%20%2F%3E%3CBR%20%2F%3E%26gt%3B%20I%20found%20the%20following%20information%20used%20as%20example%20for%20this%3A%3CBR%20%2F%3EI'll%20work%20through%20the%20example%2C%20but%20it%20looks%20like%20OPT_HOST%20is%20disabled%2C%20and%20the%20previeous%20example%20you%20gave%20indicates%20that%20this%20disables%20host%20communication%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26gt%3B%26nbsp%3BDo%20you%20want%20the%20filter%20only%20to%20communicate%20with%20the%20host%3CBR%20%2F%3ESome%20Addresses%20need%20to%20be%20sent%20to%20the%20host%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26gt%3B%26nbsp%3Bor%20communicate%20with%20the%20host%20and%20simultaneously%20send%20it%20to%20another%20llce_can%3F%3CBR%20%2F%3EAll%20other%20traffic%20not%20sent%20to%20the%20host%20should%20be%20sent%20to%20another%20interface.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26gt%3B%20Could%20you%20explain%20in%20more%20detail%20the%20behavior%20of%20your%20second%20question%3F%3CBR%20%2F%3EThe%20filter%20and%20host%20are%20set%20up%20as%20follows%3A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Ehw_ctrl%20status%20can_mask_id%20msg_id%20tag%20mb_count%20addr%20rx_intf%20entry%20mb_type%20%7C%20opt_auth%20opt_host%20logging%20opt_custom%20can_dest%3CBR%20%2F%3E10%20disabled%200x00000000%200x00000000%200x0000%200x0010%20524%205%20mask%20short%20%7C%20disabled%20enabled%20disabled%20disabled%200%3CBR%20%2F%3Eid%20routing_opts%20can_id_remap%20ch_list%3CBR%20%2F%3E0%200x00000000%200x00000000%2011%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3EIf%20I%20send%20a%20single%20message%20to%20can10%2C%20it%20gets%20routed%20to%20can%2011%2C%20as%20well%20as%20the%20host.%20Messages%20after%20that%20do%20not%20get%20routed.%20After%20I've%20sent%2016%20messages%20without%20one%20being%20delivered%2C%20the%20can%20interface%20on%20the%20host%20starts%20reporting%20a%20bus%20error%20every%20time%20I%20send%20a%20message.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20found%20the%20following%20information%20used%20as%20example%20for%20this%3A%3C%2FP%3E%0A%3CP%3E%22%3C%2FP%3E%0A%3CP%3E%23%20llcecan%20link%20up%3CBR%20%2F%3Eip%20link%20set%20up%20llcecan14%20type%20can%20bitrate%20500000%20dbitrate%205000000%20fd%20on%3CBR%20%2F%3Eip%20link%20set%20up%20llcecan15%20type%20can%20bitrate%20500000%20dbitrate%205000000%20fd%20on%3C%2FP%3E%0A%3CP%3E%23%20disable%20current%20basic%20filter%3CBR%20%2F%3Eecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Fstatus%3CBR%20%2F%3Eecho%20512%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Faddr%3CBR%20%2F%3Eecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Fexecute%3CBR%20%2F%3Eecho%20513%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Faddr%3CBR%20%2F%3Eecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fset_status%2Fexecute%3C%2FP%3E%0A%3CP%3E%23%20llcecan14%20basic%20filter%3C%2FP%3E%0A%3CP%3Eecho%200xFF%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_dest%3CBR%20%2F%3Eecho%200x7F0%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fcan_mask_id%3CBR%20%2F%3Eecho%20mask%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fentry%3CBR%20%2F%3Eecho%2014%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fhw_ctrl%3CBR%20%2F%3Eecho%200xe%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Ftag%3CBR%20%2F%3Eecho%200x10%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmb_count%3CBR%20%2F%3Eecho%20long%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmb_type%3CBR%20%2F%3Eecho%200x543%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fmsg_id%3CBR%20%2F%3Eecho%20enabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fstatus%3CBR%20%2F%3Eecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fopt_auth%3CBR%20%2F%3Eecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fopt_custom%3CBR%20%2F%3Eecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fopt_host%3CBR%20%2F%3Eecho%20disabled%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Flogging%3CBR%20%2F%3Eecho%201%20%26gt%3B%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Fadd%2Fexecute%3C%2FP%3E%0A%3CP%3Ecandump%20any%2C0%3A0%2C%23FFFFFFFF%20%26gt%3Blog%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%23%20accepted%3CBR%20%2F%3Ecansend%20llcecan15%20546%2322335566%3C%2FP%3E%0A%3CP%3E%23discarded%3CBR%20%2F%3Ecansend%20llcecan15%20556%2322335566%3C%2FP%3E%0A%3CP%3E%22%3C%2FP%3E%0A%3CP%3EAbout%20your%20first%20questions.%20Do%20you%20want%20the%20filter%20only%20to%20communicate%20with%20the%20host%3F%20or%20communicate%20with%20the%20host%20and%20simultaneously%20send%20it%20to%20another%20llce_can%3F%3C%2FP%3E%0A%3CP%3ECould%20you%20explain%20in%20more%20detail%20the%20behavior%20of%20your%20second%20question%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20this%20is%20the%20interface%20I'm%20having%20trouble%20with.%20I%20have%20some%20questions%20about%20that%20example%3C%2FP%3E%3CP%3EFirst%2C%20how%20do%20I%20set%20up%20the%20filter%20to%20communicate%20with%20the%20host%20linux%20system%3F%20How%20do%20I%20configure%20the%20lice_can_destination%20to%20not%20use%20a%20different%20CAN%20interface%3F%3C%2FP%3E%3CP%3ESecond%2C%20if%20I%20were%20to%20use%20another%20channel%20to%20achieve%20the%20same%2C%20and%20I%20set%20opt_host%20to%20I%2C%20then%20the%20first%20message%20behaves%20as%20expected%2C%20but%20then%20no%20messages%20get%20forwarded%2C%20and%20I%20start%20getting%20bus%20errors%20after%2016%20messages%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EPlease%20refer%20to%20the%20chapter%20%3CSTRONG%3E12.3.5.1%20CAN2CAN%20demo%3C%2FSTRONG%3E%20of%20the%20BSP%20User%20Manual.%3C%2FP%3E%0A%3CP%3EThere%20is%20an%20example%20adding%20a%20filter%20with%20a%20custom%20msg_id.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-02-06%20135518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-02-06%20135518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F322795i4190090E42D5943B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-02-06%20135518.png%22%20alt%3D%22Screenshot%202025-02-06%20135518.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202025-02-06%20135518.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%5BPage%20104%2C%20Linux%20BSP%2042.0%20User%20Manual%20for%20S32G2%20platforms%5D%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20looked%20at%20the%20firmware%20user%20guide%2C%20but%20I%20can't%20see%20any%20reference%20to%20the%20debugfs%20interface.%20Specifically%2C%20I'm%20having%20trouble%20creating%20a%20filter%20that%20sends%20traffic%20to%20the%20host%2C%20based%20on%20a%20mask%2C%20without%20forwarding%20that%20traffic%20to%20a%20different%20interface.%20This%20should%20be%20possible%2C%20since%20such%20filters%20are%20the%20ones%20set%20up%20by%20default%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Eoot%40s32g274a-n4c0a53%3A~%23%20cat%20%2Fsys%2Fkernel%2Fdebug%2Fllce_can_core%2Fcan_filters%2Flist%3CBR%20%2F%3Ehw_ctrl%20status%20can_mask_id%20msg_id%20tag%20mb_count%20addr%20rx_intf%20entry%20mb_type%20%7C%20opt_auth%20opt_host%3CBR%20%2F%3Elogging%20opt_custom%20can_dest%3CBR%20%2F%3E0%20enabled%200x00000000%200x00000000%200x0000%200x0010%20512%2015%20mask%20long%20%7C%3CBR%20%2F%3E1%20enabled%200x00000000%200x00000000%200x0001%200x0010%20513%2014%20mask%20long%20%7C%3CBR%20%2F%3E2%20enabled%200x00000000%200x00000000%200x0002%200x0010%20514%2013%20mask%20long%20%7C%3CBR%20%2F%3E3%20enabled%200x00000000%200x00000000%200x0003%200x0010%20515%2012%20mask%20long%20%7C%3CBR%20%2F%3E4%20enabled%200x00000000%200x00000000%200x0004%200x0010%20516%2011%20mask%20long%20%7C%3CBR%20%2F%3E5%20enabled%200x00000000%200x00000000%200x0005%200x0010%20517%2010%20mask%20long%20%7C%3CBR%20%2F%3E6%20enabled%200x00000000%200x00000000%200x0006%200x0010%20518%209%20mask%20long%20%7C%3CBR%20%2F%3E7%20enabled%200x00000000%200x00000000%200x0007%200x0010%20519%208%20mask%20long%20%7C%3CBR%20%2F%3E8%20enabled%200x00000000%200x00000000%200x0008%200x0010%20520%207%20mask%20long%20%7C%3CBR%20%2F%3E9%20enabled%200x00000000%200x00000000%200x0009%200x0010%20521%206%20mask%20long%20%7C%3CBR%20%2F%3E10%20enabled%200x00000000%200x00000000%200x010a%200x0010%20522%205%20mask%20short%20%7C%3CBR%20%2F%3E11%20enabled%200x00000000%200x00000000%200x010b%200x0010%20523%204%20mask%20short%20%7C%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3EBut%20I%20need%20to%20create%20a%20filter%20similar%20to%20these%2C%20only%20with%20a%20mask%20other%20than%200x00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELet%20me%20know%20if%20you%20have%20more%20questions.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGreat%2C%20got%20it.%20Thanks!%20Will%20see%20if%20I%20can%20get%20the%20debugFS%20interface%20figured%20out%20from%20that.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2037978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G2%20Linux%20LLCE%20debugfs%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2037978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246314%22%20target%3D%22_blank%22%3E%40m_bez%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EWhen%20you%20install%20the%20LLCE%20Driver%20%2B%20Firmware%20package%2C%20you%20can%20locate%20the%20LLCE%20Firmware%20User%20Guide%20at%3C%2FP%3E%0A%3CP%3EC%3A%5CNXP%5CS32G_LLCE_1_0_9%5Cfirmware%5Cllce_interface%5Cdoc%3C%2FP%3E%0A%3CP%3Eif%20you%20use%20the%20default%20install%20location.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
