S32G set lockstep
S32G set lockstep
2,123 次查看
liuchi
Hi All:
How to enable the lockstep mode of the S32G during the boot stage? Are there any detailed references?
I only saw the description of the lockstep register in the manual, which needs to be configured in the M7 core. Can it be configured through DCB?
Thinks!
标记 (2)
5 回复数
2,104 次查看
Joey_z
hi,liuchi
Thank you for contacting us.
Are you using the S32G2 or S32G3?
Joey
2,085 次查看
liuchi
Both s32G3 and S32G2 are in use,They are different about lockstep?
2,085 次查看
liuchi
2,052 次查看
Joey_z
hi,liuchi
Thank you for your reply.
You can refer to the BSP User Manual and find more lockstep operation.
Hope it can help you.
Joey
1,917 次查看
liuchi
Think you
