Is there a POR analog module inside S32G2?
1,164 次查看
brian_w
Inside S32G2, except the CSPD, Is there a POR analog module? If yes, what's the difference between  the function of POR and the function SPD?
From the following figure, there seems to be a individual POR ananlog module except CSPD, but I can not find the clear description in the RM.
1,150 次查看
Daniel-Aguirre
For your question, we assume analog modules is referred to internal voltage monitoring.
The following is said in S32G2 RM [Page 1204, S32G2 Reference Manual, Rev. 6, 11/2022]:
"There are no on-chip precision voltage monitors. All required precision voltage monitoring is done off-chip. Each precision voltage
monitor should be on the same sense point as the regulator for the corresponding power supply."
Please, let us know if this information was helpful or not.
1,151 次查看
Daniel-Aguirre
1,139 次查看
brian_w
Thank you for your reply.
