Our board was set up Linux on A53 and RTOS on M7
1. is it possible to get data in "internal SRAM" from an application on A53, i know that IPCF can do this work, Is there any other way we can get it?
2. below capture was from memorymap within S32G2 Reference Manual, what is the usage of "s_ram_port*" in the S32G2_Memory_Map.xls, and where can i get some introduction/material about "A53 CC FlexNOC Slave port?
