How do write the data to the flash memory in s32k148
2,102 次查看
joshfx
2,079 次查看
danielmartynek
Hi @joshfx,
Instead of FLASH_DRV_EEEWrite(), use FLASH_DRV_Program().
The FLASH_DRV_EEEWrite() is for the emulated EEPROM (FlexRAM in EEPROM mode) only.
4 回复数
2,080 次查看
danielmartynek
Hi @joshfx,
2,069 次查看
joshfx
How can i read data
2,060 次查看
danielmartynek
There is no API for reading the flash.
You can simply use a pointer to the flash location.
2,096 次查看
joshfx
I want to write a random data to spesific address in the flash memory but i can't
