s32ds 3.5
s32ds 3.5
6,817 次查看
Anjalipurushothaman
Please find attached While debugging, port is not showing up in the window. Checked the com port the board is getting detected , but in the debug configuration tab it is not showing
6,771 次查看
Mehul_Patel_NXP
Hi, @Anjalipurushothaman ,
As I see Debug option is available, please can you give a shot and hit Debug button whether it is working or not, and if follows up with any error message please can you reply with the particular error message.
Thank you. Best regards.
5 回复数
6,757 次查看
Anjalipurushothaman
6,762 次查看
Anjalipurushothaman
please find the error iam getting
6,730 次查看
Mehul_Patel_NXP
Please can you check that required driver is installed properly?
You can download relevant driver as per your system configurations from:  https://ftdichip.com/drivers/
Please can you try it and revert whether it is working or not.
- Mehul
6,702 次查看
Anjalipurushothaman
Thanks for your reply,Still the same error.
Please provide the link of required drivers for S32K3X8EVB-Q289 evaluation board on s32DS 3.5.
6,772 次查看
Mehul_Patel_NXP
