S32K144 SW32K1_ISELED_example build question
1,512件の閲覧回数
HK2
S32K144 SW32K1_ISELED_R21-11_0.9.0_D2404 Project example cannot be build.
After creating the example project file and generating the mex file code,
Build doesn't work and I'm curious why this is.
1,492件の閲覧回数
VaneB
Hi @HK2
Please verify that the S32K1 support package and the S32K1 RTD version 2.0.0 are correctly installed. Also, check if the project properties > C/C++ Build > Environment you have the GCC's path.
B.R.
VaneB
