S32K144 SW32K1_ISELED_example build question
1,513 次查看
HK2
S32K144 SW32K1_ISELED_R21-11_0.9.0_D2404 Project example cannot be build.
After creating the example project file and generating the mex file code,
Build doesn't work and I'm curious why this is.
1,493 次查看
VaneB
Hi @HK2
Please verify that the S32K1 support package and the S32K1 RTD version 2.0.0 are correctly installed. Also, check if the project properties > C/C++ Build > Environment you have the GCC's path.
B.R.
VaneB
