Hello there,
I got some errors when created an S32G RTD configuration project in S32DS.
these errors show that peripherals drivers are not found in toolchain/IDE project.
see attached image.
any suggestion?
Many thanks.
Solved! Go to Solution.
the problem solved.
right click error and then "add ..." will solve the issue.
Hi nxp
when I trying to install RTD as S32 Design Studio v3.4.1及RTD 2.0.0 HF4安装指南_v20210810.pdf
Can you please try:
https://nxp.flexnetoperations.com/control/frse/product?child_plneID=832137
B.R.,
Rick
Hi Rick
tks,it working.
B.R
