S32DS for ARM 2018R1 license
BoxLi
Hi:
My license of S32DS for ARM 2018R1 IDE has expired. Could you help check and extend it for me?
Thanks.
mikedoidge
I've extended your entitlement. Please refresh or re-activate your installation.
Mike
Mehul_Patel_NXP
Hi, @ScreenUser ,
I have extended your license expiration to 2027.
Please use the 'Refresh' action in the NXP License menu to update your local license info.
- Mehul Patel
Hansheng
Hello, My license  expired now, please help to extended license , active code :93E3-80E7-2A38-9E70
Mehul_Patel_NXP
Hi, @Hansheng ,
I have extended your license through end of 2027. Please refresh the activation to use it.
Thank you. Best regards.
-Mehul Patel
Hansheng
ligeng
Good morning,
my license of S32 Design Studio for Power Architecture Version 2.1 IDE has expired. Could you please extend it for me?
Activation Code DBA1-317C-5265-7E4F
Thanks a lot.
mikedoidge
Hello Gen Li,
I have extended your license for 3 years.
Please re-activate using current activation code.
Mike
zuqiao
Hello NXP expert,
My S32DS for Arm v2018 license has expired, the license has been returned and it shows the license is missing by now, please help to extend the license, thanks a lot !
David
Mehul_Patel_NXP
Hi, @zuqiao ,
Please can you share the activation code for the S32DS for Arm v2018, so that I can reactivate your license.
-Mehul Patel
zuqiao
The activation code is D876-C313-75B1-2E1B , thanks.
Mehul_Patel_NXP
Hi, @zuqiao ,
I have extended your license through end of December - 2026.
Please refresh the activation.
Thank you. Kind regards.
- Mehul Patel
zuqiaoyang
Hi, Mehul_Patel,
S32DS works now, thank you very much !!!
ftalarico
Hi, my licence is expired, can you help me to extend it?
The number is
09D2-DE37-6529-87FB
Thank you.
Francesco
mikedoidge
I have extended your license through 2025. Please re-activate with the same code.
Mike
cjgyf
My license has also expired (9DE8-C6AE-8B6B-952B), could you extend it for me? Thank you very much!
Mehul_Patel_NXP
Hi, @cjgyf ,
I've extended your entitlement through end of December 2025. Please refresh or re-activate your installation.
- Mehul Patel
francesco_solit
Good morning.
Our licence for S32DS for ARM 2018R1 is going to expire. Could you please extend it? You can find it in attachment.
Thank you and kind regards,
Francesco Solito
mikedoidge
Hello @francesco_solit,
I have extended your entitlement. Please refresh the license so it will receive the new expiration date.
Mike
francesco_solit
Thnk you very much mike.
Kind regards,
Francesco Solito
francesco_solit
Hello Mike
The re-activation is now working on my PC, but it is no more working on the other PCs of my colleagues, where in the past the same licence was working. Is it possible to extend the license also for my colleagues? Or is it possible to receive new licences for them? Their NXP accounts are:
federico.bocconi@metasystemcorporation.com
matteo.cocconcelli@metasystem.it
Thank you in advance and kind regards,
Francesco Solito
mikedoidge
I checked the server logs for this entitlement. It is reporting the maximum number of returned licenses has been reached. I reset the count, so it should work now. Please ask your colleagues to try again.
Please also note, your colleagues could get their own license if they use the following link and login to their NXP.com account:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32-DS-ARM_v2018
Mike
francesco_solit
Hello Mike
Sorry for the delay. Thank you very much. Now everything is working correctly.
Kind regards,
Francesco
