S32 Design Studio for ARM 2.2 – License activation error (CLLReason errorNo=27: maximum number of re
baikjongyoub
I am having a license activation problem with S32 Design Studio for ARM v2.2 and I can no longer use the tool.
  • Product: S32 Design Studio for ARM
  • Version: 2.2
  • OS: Windows 10 (64-bit)
  • License type: Node-locked (activation code)
  • Activation Code: 3668-673A-125A-5626
When I start S32DS, the Product Licenses window shows:
Status: License missing
If I click Activate and enter my activation code, I immediately get the following error:
CLLReason [errorNo=27, errorString=Error sending an return request to a remote activation server and processing the response. The maximum number of returns is reached, contact your product vendor if you need help. (FNP error 0), flxActMajorErrNo=0, flxActMinorErrNo=0, flxActSysErrNo=0, flxCommErrNo=0]
From what I understand, this means that the maximum number of returns/moves for this activation code has been reached.
In the past I have reinstalled S32DS and/or Windows several times, so the license might have been returned/activated many times.
I have already tried:
  • Running S32DS as Administrator
  • Checking my internet connection and firewall/proxy settings
  • Using both online activation and the “Generate offline request” option
The problem is still the same and I cannot activate the product anymore.
Could you please reset the return counter for this activation code or issue a new activation code so that I can activate S32 Design Studio for ARM 2.2 on my current PC?
I can provide any additional information (log files, screenshots, etc.) if needed.
Thank you in advance for your help.
jongyoub baik.
jiri_kral
you should be able activate S32DS again with your old code.
jiri_kral
tk8357
I'm having this same issue and I can't seem to figure out how to fix it
%3CLINGO-SUB%20id%3D%22lingo-sub-2207285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%20for%20ARM%202.2%20%E2%80%93%20License%20activation%20error%20(CLLReason%20errorNo%3D27%3A%20maximum%20number%20of%20re%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20having%20a%20license%20activation%20problem%20with%20%3CSTRONG%3ES32%20Design%20Studio%20for%20ARM%20v2.2%3C%2FSTRONG%3E%20and%20I%20can%20no%20longer%20use%20the%20tool.%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EProduct%3A%3C%2FSTRONG%3E%20S32%20Design%20Studio%20for%20ARM%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EVersion%3A%3C%2FSTRONG%3E%202.2%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EOS%3A%3C%2FSTRONG%3E%20Windows%2010%20(64-bit)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ELicense%20type%3A%3C%2FSTRONG%3E%20Node-locked%20(activation%20code)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EActivation%20Code%3A%3C%2FSTRONG%3E%203668-673A-125A-5626%26nbsp%3B%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EWhen%20I%20start%20S32DS%2C%20the%20Product%20Licenses%20window%20shows%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EStatus%3A%20License%20missing%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EIf%20I%20click%20%3CSTRONG%3EActivate%3C%2FSTRONG%3E%20and%20enter%20my%20activation%20code%2C%20I%20immediately%20get%20the%20following%20error%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3ECLLReason%20%5BerrorNo%3D27%2C%20errorString%3DError%20sending%20an%20return%20request%20to%20a%20remote%20activation%20server%20and%20processing%20the%20response.%20The%20maximum%20number%20of%20returns%20is%20reached%2C%20contact%20your%20product%20vendor%20if%20you%20need%20help.%20(FNP%20error%200)%2C%20flxActMajorErrNo%3D0%2C%20flxActMinorErrNo%3D0%2C%20flxActSysErrNo%3D0%2C%20flxCommErrNo%3D0%5D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EFrom%20what%20I%20understand%2C%20this%20means%20that%20the%20maximum%20number%20of%20returns%2Fmoves%20for%20this%20activation%20code%20has%20been%20reached.%3CBR%20%2F%3EIn%20the%20past%20I%20have%20reinstalled%20S32DS%20and%2For%20Windows%20several%20times%2C%20so%20the%20license%20might%20have%20been%20returned%2Factivated%20many%20times.%3C%2FP%3E%3CP%3EI%20have%20already%20tried%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ERunning%20S32DS%20as%20Administrator%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EChecking%20my%20internet%20connection%20and%20firewall%2Fproxy%20settings%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUsing%20both%20online%20activation%20and%20the%20%E2%80%9CGenerate%20offline%20request%E2%80%9D%20option%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThe%20problem%20is%20still%20the%20same%20and%20I%20cannot%20activate%20the%20product%20anymore.%3C%2FP%3E%3CP%3E%3CSTRONG%3ECould%20you%20please%20reset%20the%20return%20counter%20for%20this%20activation%20code%20or%20issue%20a%20new%20activation%20code%20so%20that%20I%20can%20activate%20S32%20Design%20Studio%20for%20ARM%202.2%20on%20my%20current%20PC%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20can%20provide%20any%20additional%20information%20(log%20files%2C%20screenshots%2C%20etc.)%20if%20needed.%3C%2FP%3E%3CP%3EThank%20you%20in%20advance%20for%20your%20help.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3Ejongyoub%20baik.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2207809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202.2%20%E2%80%93%20License%20activation%20error%20(CLLReason%20errorNo%3D27%3A%20maximum%20number%20o%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eyou%20should%20be%20able%20activate%20S32DS%20again%20with%20your%20old%20code.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202.2%20%E2%80%93%20License%20activation%20error%20(CLLReason%20errorNo%3D27%3A%20maximum%20number%20o%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20having%20this%20same%20issue%20and%20I%20can't%20seem%20to%20figure%20out%20how%20to%20fix%20it%3C%2FP%3E%3C%2FLINGO-BODY%3E
