Regarding Debugging
Regarding Debugging
BharathKumar204
FS32K148UJVLU Micro controller Series I am not able to debugging.
once build is completed After that  gdb launching failed and version is different this type of error message is came.
Please help me is their any solution for that error.
BharathKumar204
Actually that problem is solved.
I have another dought How to interface I2C,SPI,CAN with S32K148 Evaluation Kit. Please Give me the Basic Software Program.
mikedoidge
There are examples for each of these included in the RTD/SDK. You can see them in the New Project from Example wizard after the SDK package is installed to S32DS.
Mike
Daniel-Aguirre
What is the error that cames when failing debugging? What kind of debugger are you using? Are you using an EVK provided by NXP?
At this moment, we are trying to have a better understanding of your problem. Can you elaborate more on this?
Please, let us know.
