hi team,
i met SWO trace capture can't work on S32DS V3.4 with S32K344EVB.
i enabled SWO protocol and Streaming in debug configuration. then i launched debugging, and add SWO trace capture window,
enabled trace and variable to be traced. as below
then i start trace, but no trace output
Hi Guys.
Could you please help on my question. Thanks a lot
Hi, Alvin Liu,
I read the file"S32K3_OTA_AB_SWAP_Demostration.pdf",
but I can't find the demo project on page 9,
s32ds Project "S32K344_HSE_FW_INSTALL_Demo_V110_ABSwap".
"Installing HSE Firmware FW to S32K344_readme.pdf"
Can you send me by email??
chdp75@163.com
thanks a lot...
