Problems with High DPI displays
1,828 次查看
reneherrero
I got a shiny new Dell Precision 5510 mobile workstation with a 4k display which is marvelous.  Problem: the S32 Design Studio for ARM can't cope with the 3840 x 2160 resolution.
The problem is not with S32 IDE, but with the underlying Eclipse Luna (4.4.2) platform.  As you can see from the image down below, it makes the IDE pretty much unworkable.
Most of these scaling issues have been fixed in Eclipse Neon (still broken in Mars).
Any chance you guys can add this to your backlog?
Rene
标记 (3)
1,699 次查看
stanish
Hello Rene,
Thanks for pointing on this issue!
I've logged this issue into our defect tracking system under the number ENGR00381768.
Our product team can consider it in next S32DS releases.
Stan
1,699 次查看
reneherrero
Thanks Stan.
FYI - Same is happening with the Kinetis IDE...
