Indexer Problem in S32DS for Power V1.2
1,958件の閲覧回数
建浩章
I  have created a new project in S32DS for Power V1.2, and the project is always in the index. I waited for a long time, then the index progress bar was still 0, and at this time, the S32DS running very slowly. If you has encountered this problem and solved it, please leave a message, thank you very muchProblem.png
タグ(2)
2 返答(返信)
1,841件の閲覧回数
jiri_kral
It is possible for you switch from S32DS for Power v1.2 to S32DS Power 2017.R1?
We were facing similar issue for couple customers when Network connection was active - really slow IDE and build. But this issue was caused by some firewall settings on Customer side. You can try remove network cable and see if it helps.
Jiri
1,841件の閲覧回数
建浩章
   Thanks for your reply. I tried the method you recommended, but it didn’t work. Anyway, thank you very much.
