Failure for OpenSDA interface
1,371 次查看
hrfbit
I am a new user for S32DS and trying to use S32DS Power and MPC5748G DevKit Board with OpenSDA interface to debug the "hello+pll". However, there was an error that the device could not be found as shown in the following pictrues.
what's more, the version is shown as following:
In addition to this problem, I do not know where to learn the specific operation of debugging. Hope to get help form yours. Thank you!
1,274 次查看
stanish
1,274 次查看
jiri_kral
did you checked out the power? Are all three green LEDs at the end with Ethernet connector ON? If not and you are powering the board from USB - switch the Jumper (there is only one) to position close to ETH connector.
Jiri
