FS32K144 Program FOPT Register
4,317件の閲覧回数
gary_yang
We tested the address 0x40D (FOPT Register) write 0x7F, after address 0x400 can not read
If 0xFF is written at address 0x40D (FOPT Register), it can be read correctly.
Kindly give us your advice. Thank you.
Gary
タグ(3)
7 返答(返信)
4,093件の閲覧回数
jiri_kral
um, I'm lost a little bit. What you mean by after address 0x400 can not read?
In my case - there is 7F  in FOPT, and memory can be read without any issue:
Jiri
4,093件の閲覧回数
gary_yang
I programmed the hex file (address 0x40D write 0x7F), read back and found that address after  0x400 can not be read correctly.
But programming the same hex file (changing address 0x40D to write 0xFF or 0xDF) can be read correctly,
Gary
4,093件の閲覧回数
jiri_kral
what software and debug probe are you using?
Jiri
4,093件の閲覧回数
gary_yang
We are programmer manufacturer.
Currently encountered problems in the development of FS32K144 programming process,that is the picture of our software and we used J-Link in debug and verify.
Thank you
Gary
4,093件の閲覧回数
jiri_kral
I tried the same scenario with Segger J-Link - SEGGER J-Link GDB Server V6.42a - and there is no issue with memory read when FOPT contains 0x7F. There must be some issue with your SW.
Jiri
4,093件の閲覧回数
gary_yang
I think that our software must set registers during initialization and avoid problems.
Can you help us with suggestions?
Thank you
Gary
4,093件の閲覧回数
jiri_kral
to be honest, I'm not familiar with debugger low level communication. But you can compare - for example - register content for PE micro (or segger) debug session with your debug session and try to find differences.
Jiri
