S32DS PA elf file format is 64bit?
2,741 次查看
wuguoqiang
The elf file generated by S32DS PA is 64bit?
If so ,how to generate 32bit elf?
标记 (3)
4 回复数
2,648 次查看
jiri_kral
by default the elf file is 32 bit. What is your target MCU?
Jiri
2,648 次查看
wuguoqiang
by the way, my OS on laptop is WIN7
2,648 次查看
wuguoqiang
MPC5744P. How to change the elf format,32bit or 64bit?
2,648 次查看
jiri_kral
MPC5744P is 32 bit machine, there is no way how to use 64bit elf with this MCU.
Jiri
