Capture IDE Debugger Console Output to Local File
Dave_the_coder
Is there a built-in IDE method to export or re-direct the S32 Design Studion Debugger Console content to a local file?
I'm using the IDE debugger console to display large data arrays that are being used to capture realtime diagnostic information for seperate analysis, (using debugger commands like print -array on -array-indexes on -elements unlimited -pretty off -- waitrec_m)  but I have to manually select/copy the resulting console text in order to save it elsewhere.
I'm hoping to be able to better automate this process.
Julián_AragónM
Hi @Dave_the_coder,
If you are using Semihosting to print into the console, you can use fprint instead to write directly into a file. Please look at the following community posts:
Julián
Julián_AragónM
Hi @Dave_the_coder,
Julián
Dave_the_coder
Julián - Thank you for taking the time to respond, it is greatly appreciated!
Unfortunately, I cannot embed any Semihosting functions into the code I am testing as it has time-critical behaviour that breaks with the addition of fprintf() or similar library calls. I only have enough throughput capacity to write diagnostic data directly into ram-based arrays - after hitting a breakpoint I then have to display the captured data to the debug console and it is from that I am trying to capture the resulting console output.
I have looked through the available debug console commands but have not yet identified (or understood) anything that allows the console output to be redirected.
Regardless, thank you again for your suggestions.
Dave
Julián_AragónM
Hi @Dave_the_coder,
I'm not sure if this is the option you are looking for, but you can also select an output file from "Debug Configurations > Standard Input and Output"
Julián
Dave_the_coder
Thank you for your suggestion Julián
- unfortunately, I believe that this still relies on the use of the stdio library functions that as per my prevous explanation I can't use in my design.
I was hoping to find debugger console command options that would re-direct the console command output to a local file.
For example, the debugger console command 'print' supports a variety of command line options to format and display program variables and memory to the console, but I cannot identify any setting to redirect that command output to a local file.
Dave
Dave_the_coder
To clarify:
I have been referring to the output obtained from the IDE Debugger Console :
- not the Standard input/Output console:
Dave
Dave_the_coder
I finally located the answer - the IDE debug console has commands 'dump' and 'set logging' options to redirect the output to a local file.
The answer was in one of the links 1st provided by Julián (Redirect debug console to file - NXP Community) - I completely missed the references in that link!
Julián - Apologies and Thanks!
Dave
Julián_AragónM
No problem, Dave! I'm Glad you were able to find the solution.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-1925465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECapture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1925465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20there%20a%20built-in%20IDE%20method%20to%20export%20or%20re-direct%20the%20S32%20Design%20Studion%20Debugger%20Console%20content%20to%20a%20local%20file%3F%3C%2FP%3E%3CP%3EI'm%20using%20the%20IDE%20debugger%20console%20to%20display%20large%20data%20arrays%20that%20are%20being%20used%20to%20capture%20realtime%20diagnostic%20information%20for%20seperate%20analysis%2C%20(using%20debugger%20commands%20like%26nbsp%3B%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eprint%20-array%20on%20-array-indexes%20on%20-elements%20unlimited%20-pretty%20off%20--%20waitrec_m%3C%2FFONT%3E)%26nbsp%3B%20but%20I%20have%20to%20manually%20select%2Fcopy%20the%20resulting%20console%20text%20in%20order%20to%20save%20it%20elsewhere.%3C%2FP%3E%3CP%3EI'm%20hoping%20to%20be%20able%20to%20better%20automate%20this%20process.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1925465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EEclipse%20IDE%20Usage%20and%20Settings%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1927600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%20problem%2C%20Dave!%20I'm%20Glad%20you%20were%20able%20to%20find%20the%20solution.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1927284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20finally%20located%20the%20answer%20-%20the%20IDE%20debug%20console%20has%20commands%20'dump'%20and%20'set%20logging'%20options%20to%20redirect%20the%20output%20to%20a%20local%20file.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20answer%20was%20in%20one%20of%20the%20links%201st%20provided%20by%20Juli%C3%A1n%20(Redirect%20debug%20console%20to%20file%20-%20NXP%20Community)%20-%20I%20completely%20missed%20the%20references%20in%20that%20link!%3CBR%20%2F%3E%3CBR%20%2F%3EJuli%C3%A1n%20-%20Apologies%20and%20Thanks!%3CBR%20%2F%3E%3CBR%20%2F%3EDave%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1927148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETo%20clarify%3A%3C%2FP%3E%3CP%3EI%20have%20been%20referring%20to%20the%20output%20obtained%20from%20the%20IDE%20Debugger%20Console%20%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Dave_the_coder_0-1723018721083.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dave_the_coder_0-1723018721083.png%22%20style%3D%22width%3A%20153px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F292325i46EEB44F5F7A12F0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Dave_the_coder_0-1723018721083.png%22%20alt%3D%22Dave_the_coder_0-1723018721083.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDave_the_coder_0-1723018721083.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CP%3E-%20not%20the%20Standard%20input%2FOutput%20console%3A%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Dave_the_coder_1-1723018821091.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Dave_the_coder_1-1723018821091.png%22%20style%3D%22width%3A%20102px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F292328i05E58E8FFE34CE76%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Dave_the_coder_1-1723018821091.png%22%20alt%3D%22Dave_the_coder_1-1723018821091.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDave_the_coder_1-1723018821091.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDave%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1927137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20suggestion%20Juli%C3%A1n%3CBR%20%2F%3E-%20unfortunately%2C%20I%20believe%20that%20this%20still%20relies%20on%20the%20use%20of%20the%20stdio%20library%20functions%20that%20as%20per%20my%20prevous%20explanation%20I%20can't%20use%20in%20my%20design.%3CBR%20%2F%3EI%20was%20hoping%20to%20find%20debugger%20console%20command%20options%20that%20would%20re-direct%20the%20console%20command%20output%20to%20a%20local%20file.%3CBR%20%2F%3EFor%20example%2C%20the%20debugger%20console%20command%20'print'%20supports%20a%20variety%20of%20command%20line%20options%20to%20format%20and%20display%20program%20variables%20and%20memory%20to%20the%20console%2C%20but%20I%20cannot%20identify%20any%20setting%20to%20redirect%20that%20command%20output%20to%20a%20local%20file.%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3CBR%20%2F%3EDave%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1926629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1926629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F215334%22%20target%3D%22_blank%22%3E%40Dave_the_coder%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20not%20sure%20if%20this%20is%20the%20option%20you%20are%20looking%20for%2C%20but%20you%20can%20also%20select%20an%20output%20file%20from%20%22Debug%20Configurations%20%26gt%3B%20Standard%20Input%20and%20Output%22%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_0-1722966980712.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1722966980712.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F292240iDA25B1BBFF88E3FA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_0-1722966980712.png%22%20alt%3D%22Julin_AragnM_0-1722966980712.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJulin_AragnM_0-1722966980712.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1926132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1926132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EJuli%C3%A1n%20-%20Thank%20you%20for%20taking%20the%20time%20to%20respond%2C%20it%20is%20greatly%20appreciated!%3CBR%20%2F%3E%3CBR%20%2F%3EUnfortunately%2C%20I%20cannot%20embed%20any%20Semihosting%20functions%20into%20the%20code%20I%20am%20testing%20as%20it%20has%20time-critical%20behaviour%20that%20breaks%20with%20the%20addition%20of%20fprintf()%20or%20similar%20library%20calls.%20I%20only%20have%20enough%20throughput%20capacity%20to%20write%20diagnostic%20data%20directly%20into%20ram-based%20arrays%20-%20after%20hitting%20a%20breakpoint%20I%20then%20have%20to%20display%20the%20captured%20data%20to%20the%20debug%20console%20and%20it%20is%20from%20that%20I%20am%20trying%20to%20capture%20the%20resulting%20console%20output.%3CBR%20%2F%3EI%20have%20looked%20through%20the%20available%20debug%20console%20commands%20but%20have%20not%20yet%20identified%20(or%20understood)%20anything%20that%20allows%20the%20console%20output%20to%20be%20redirected.%3CBR%20%2F%3E%3CBR%20%2F%3ERegardless%2C%20thank%20you%20again%20for%20your%20suggestions.%3CBR%20%2F%3EDave%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1925579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Capture%20IDE%20Debugger%20Console%20Output%20to%20Local%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1925579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F215334%22%20target%3D%22_blank%22%3E%40Dave_the_coder%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%20lang%3D%22es-MX%22%3EIf%20you%20are%20using%20Semihosting%20to%20print%20into%20the%20console%2C%20you%20can%20use%20fprint%20instead%20to%20write%20directly%20into%20a%20file.%20Please%20look%20at%20the%20following%20community%20posts%3A%3C%2FP%3E%0A%3CUL%20type%3D%22disc%22%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers%2FWriting-to-a-file-fprintf-in-MCUXpresso-IDE-11-3-1%2Fm-p%2F1289245%22%20target%3D%22_blank%22%3ESolved%3A%20Writing%20to%20a%20file%20(fprintf)%20in%20MCUXpresso%20IDE%20(11.3.1)%20-%20NXP%20Community%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FRedirect-debug-console-to-file%2Ftd-p%2F1228946%22%20target%3D%22_blank%22%3ERedirect%20debug%20console%20to%20file%20-%20NXP%20Community%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20lang%3D%22es-MX%22%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
