Build is producing error message: unrecognized option '-T'
2,982件の閲覧回数
347996379
I created a new project with "S32DS project from a example",but an exception message occurred when I compiled.
I don't have any ideas,can you help me?
thanks!
タグ(3)
2,891件の閲覧回数
347996379
Thank you for your help. I have solved my problem, which was caused by the encryption system
5 返答(返信)
2,892件の閲覧回数
347996379
2,891件の閲覧回数
347996379
this is output from build console.
2,891件の閲覧回数
jiri_kral
unfortunately your attached project is somehow encrypted. So - it looks that there is some syntax error in linker script file. Can you share your .ld file?
Jiri
2,891件の閲覧回数
347996379
The accessory  is my project. The image is my compile interface.
2,891件の閲覧回数
jiri_kral
can you please share output from build console?
Jiri
