Build is producing error message: unrecognized option '-T'
347996379
I created a new project with "S32DS project from a example",but an exception message occurred when I compiled.
I don't have any ideas,can you help me?
thanks!
Tags (3)
347996379
Thank you for your help. I have solved my problem, which was caused by the encryption system
347996379
347996379
this is output from build console.
jiri_kral
unfortunately your attached project is somehow encrypted. So - it looks that there is some syntax error in linker script file. Can you share your .ld file?
Jiri
347996379
The accessory  is my project. The image is my compile interface.
jiri_kral
can you please share output from build console?
Jiri
