I created a new project with "S32DS project from a example",but an exception message occurred when I compiled.
I don't have any ideas,can you help me?
thanks!
Solved! Go to Solution.
Thank you for your help. I have solved my problem, which was caused by the encryption system
this is output from build console.
unfortunately your attached project is somehow encrypted. So - it looks that there is some syntax error in linker script file. Can you share your .ld file?
Jiri
The accessory is my project. The image is my compile interface.
can you please share output from build console?
