HOWTO: Create An ISP Project From Example in S32DS for Vision
S32DS for Vision contains many example projects from which you can learn how S32DS for Vision can be used with the help of the Vision SDK to develop vision applications. The example projects contain generated and hand-written code, which utilize the Vision SDK to demonstrate a workflow using S32DS for Vision. In this document, the procedure for creating a project from one of the provided ISP examples through to execution on the EVB is detailed.
1) Launch S32DS for Vision
2) Select "New S32DS Project from example"
3) Select isp_sonyimx224_csi_dcu project
   In this particular project, the ISP graph diagram is included. If you wish to view it, go to the Project Explorer panel and expand 'isp_sonyimx224_csi_dcu_graph'. Then double click on 'ISP data flow : isp_sonyimx224_csi_dcu_graph'. The ISP graph diagram will appear in the editor panel.
4) Change to C/C++ perspective, click on 'Switch to C/C++ Development'
5) Select isp_sonyimx224_csi_dcu: A53 in the Project Explorer panel
6) Build project for A53
7) Start a debug session using method as described in HOWTO Create A53 Linux Project in S32DS for Vision, beginning at step 9.
8) Should get results similar to this:
评论
Hi  Mike Doidge
     It is helpful when i follow your guide to create project. But i encounter a strange issue. Could you help me for this? Thanks.
My S32 DS is :S32 Design Studio for Vision Version 2018.R1
PC OS version: ubuntu 14.04 64bits
When i build the project, the logs shown as below:
13:42:02 **** Build of configuration A53 for project isp_sonyimx224_csi_dcu ****
make -j4 all
make --no-print-directory pre-build
rm -f ../A53_gen/src/sequencer_srec.c; make -f ../Project_Settings/Scripts/seq.mk TD="/root/NXP/S32DS_Vision_v2018.R1/eclipse/../Cross_Tools/gcc-6.3-arm32-eabi" VD="/root/NXP/S32DS_Vision_v2018.R1/eclipse/../S32DS/s32v234_sdk"
make[2]: dos2unix: Command not found
make --no-print-directory main-build
Building file: ../A53_src/main.cpp
Invoking: Standard S32DS C++ Compiler
aarch64-linux-gnu-g++ "@A53_src/main.args" -MMD -MP -MF"A53_src/main.d" -MT"A53_src/main.o" -o "A53_src/main.o" "../A53_src/main.cpp"
make[2]: *** [../A53_gen/src/sequencer_srec.c] Error 127
make[1]: [pre-build] Error 2 (ignored)
Building file: ../A53_gen/src/kmem.c
Building file: ../A53_gen/src/mipi_simple.c
Invoking: Standard S32DS C Compiler
aarch64-linux-gnu-gcc "@A53_gen/src/kmem.args" -MMD -MP -MF"A53_gen/src/kmem.d" -MT"A53_gen/src/kmem.o" -o "A53_gen/src/kmem.o" "../A53_gen/src/kmem.c"
aarch64-linux-gnu-gcc "@A53_gen/src/kmem.args" -MMD -MP -MF"A53_gen/src/mipi_simple.d" -MT"A53_gen/src/mipi_simple.o" -o "A53_gen/src/mipi_simple.o" "../A53_gen/src/mipi_simple.c"
Finished building: ../A53_gen/src/kmem.c
Finished building: ../A53_gen/src/mipi_simple.c
Finished building: ../A53_src/main.cpp
Building target: s32ds_isp_sonyimx224_csi_dcu.elf
Invoking: Standard S32DS C++ Linker
aarch64-linux-gnu-g++ -o "s32ds_isp_sonyimx224_csi_dcu.elf" "@s32ds_isp_sonyimx224_csi_dcu.args"
./A53_src/main.o: In function `LibsPrepare(AppContext&)':
/root/workspaceS32DS.Vision.2018.R1/isp_sonyimx224_csi_dcu/isp_sonyimx224_csi_dcu/A53/../A53_src/main.cpp:298: undefined reference to `sequencer_srec'
collect2: error: ld returned 1 exit status
make[1]: *** [s32ds_isp_sonyimx224_csi_dcu.elf] Error 1
make: *** [all] Error 2
13:42:07 Build Finished (took 4s.477ms)
Description Resource Path Location Type
Ld error: 2 (ignored) C/C++ Problem
Ld error: undefined reference to `sequencer_srec' isp_sonyimx224_csi_dcu C/C++ Problem
make: *** [all] Error 2 isp_sonyimx224_csi_dcu C/C++ Problem
make[1]: *** [s32ds_isp_sonyimx224_csi_dcu.elf] Error 1 isp_sonyimx224_csi_dcu C/C++ Problem
make[2]: *** [../A53_gen/src/sequencer_srec.c] Error 127 isp_sonyimx224_csi_dcu C/C++ Problem
are you able build ISP target?
If not, please share the output from build console.
Jiri
%3CLINGO-SUB%20id%3D%22lingo-sub-1114652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%EF%BC%9A%E6%A0%B9%E6%8D%AE%20S32DS%20for%20Vision%20%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%88%9B%E5%BB%BA%20ISP%20%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ES32DS%20for%20Vision%20%E5%8C%85%E5%90%AB%E8%AE%B8%E5%A4%9A%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%B8%AD%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E5%9C%A8%20Vision%20SDK%20%E7%9A%84%E5%B8%AE%E5%8A%A9%E4%B8%8B%E4%BD%BF%E7%94%A8%20S32DS%20for%20Vision%20%E5%BC%80%E5%8F%91%E8%A7%86%E8%A7%89%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E5%8C%85%E5%90%AB%E7%94%9F%E6%88%90%E7%9A%84%E5%92%8C%E6%89%8B%E5%86%99%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%88%A9%E7%94%A8%20Vision%20SDK%20%E6%BC%94%E7%A4%BA%E4%BD%BF%E7%94%A8%20S32DS%20for%20Vision%20%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%B5%81%E7%A8%8B%E3%80%82%E6%9C%AC%E6%96%87%E6%A1%A3%E8%AF%A6%E7%BB%86%E4%BB%8B%E7%BB%8D%E4%BA%86%E4%BB%8E%E6%8F%90%E4%BE%9B%E7%9A%84%20ISP%20%E7%A4%BA%E4%BE%8B%E4%B9%8B%E4%B8%80%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%E5%88%B0%E5%9C%A8%20EVB%20%E4%B8%8A%E6%89%A7%E8%A1%8C%E7%9A%84%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1%EF%BC%89%E5%90%AF%E5%8A%A8S32DS%20for%20Vision%3C%2FP%3E%3CP%3E2%EF%BC%89%E9%80%89%E6%8B%A9%E2%80%9C%E4%BB%8E%E7%A4%BA%E4%BE%8B%E4%B8%AD%E6%96%B0%E5%BB%BAS32DS%E9%A1%B9%E7%9B%AE%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F70958i0AF1988D904BAE19%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3%EF%BC%89%E9%80%89%E6%8B%A9%3CSTRONG%3Eisp_sonyimx224_csi_dcu%3C%2FSTRONG%3E%E9%A1%B9%E7%9B%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20802px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71225iD3B60CCF003E5017%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E7%89%B9%E5%AE%9A%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E5%8C%85%E5%90%AB%E4%BA%86%20ISP%20%E5%9B%BE%E8%A1%A8%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B8%8C%E6%9C%9B%E6%9F%A5%E7%9C%8B%E5%AE%83%EF%BC%8C%E8%AF%B7%E8%BD%AC%E5%88%B0%20Project%20Explorer%20%E9%9D%A2%E6%9D%BF%E5%B9%B6%E5%B1%95%E5%BC%80%E2%80%9C%20%3CSTRONG%3Eisp_sonyimx224_csi_dcu_graph%3C%2FSTRONG%3E%20%E2%80%9D%E3%80%82%E7%84%B6%E5%90%8E%E5%8F%8C%E5%87%BB%E2%80%9C%20%3CSTRONG%3EISP%20%E6%95%B0%E6%8D%AE%E6%B5%81%EF%BC%9Aisp_sonyimx224_csi_dcu_graph%3C%2FSTRONG%3E%20%E2%80%9D%E3%80%82ISP%20%E5%9B%BE%E8%A1%A8%E5%B0%86%E5%87%BA%E7%8E%B0%E5%9C%A8%E7%BC%96%E8%BE%91%E5%99%A8%E9%9D%A2%E6%9D%BF%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71271iF43EBF579808D089%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4%EF%BC%89%E5%88%87%E6%8D%A2%E5%88%B0%20C%2FC%2B%2B%20%E8%A7%86%E8%A7%92%EF%BC%8C%E7%82%B9%E5%87%BB%E2%80%9C%E5%88%87%E6%8D%A2%E5%88%B0%20C%2FC%2B%2B%20%E5%BC%80%E5%8F%91%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71320iFC9BB4298206920F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5%EF%BC%89%E5%9C%A8Project%20Explorer%E9%9D%A2%E6%9D%BF%E4%B8%AD%E9%80%89%E6%8B%A9%3CSTRONG%3Eisp_sonyimx224_csi_dcu%3AA53%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20446px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71411i87AF39336556E7A7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6%EF%BC%89%E6%9E%84%E5%BB%BA%3CSTRONG%3EA53%3C%2FSTRONG%3E%E9%A1%B9%E7%9B%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71226i7B16D7F16BC8F0EC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20136px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F70912i9E8E3F0877CAF748%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E7%EF%BC%89%E4%BB%8E%E6%AD%A5%E9%AA%A49%E5%BC%80%E5%A7%8B%EF%BC%8C%E4%BD%BF%E7%94%A8%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335006%22%20target%3D%22_blank%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8S32DS%E4%B8%AD%E4%B8%BAVision%E5%88%9B%E5%BB%BAA53%20Linux%E9%A1%B9%E7%9B%AE%3C%2FA%3E%E4%B8%AD%E6%89%80%E8%BF%B0%E6%96%B9%E6%B3%95%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FP%3E%3CP%3E8%EF%BC%89%E5%BA%94%E8%AF%A5%E5%BE%97%E5%88%B0%E7%B1%BB%E4%BC%BC%E8%BF%99%E6%A0%B7%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20585px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74199i075C2F9052FB430F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E6%A0%B9%E6%8D%AES32DS%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%B8%BAVision%E5%88%9B%E5%BB%BAISP%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%BB%BA%E7%AB%8B%20ISP%20%E7%9B%AE%E6%A0%87%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20741px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72092i4C401793CF58348E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E8%AF%B7%E5%88%86%E4%BA%AB%E6%9E%84%E5%BB%BA%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9A%84%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJiri%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E6%A0%B9%E6%8D%AES32DS%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%B8%BAVision%E5%88%9B%E5%BB%BAISP%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmikedoidge%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3E%E8%BF%88%E5%85%8B%C2%B7%E9%81%93%E5%A5%87%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E6%8C%87%E5%8D%97%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E5%AE%83%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E4%BD%86%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%A5%87%E6%80%AA%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E8%BF%99%E4%B8%AA%E5%BF%99%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84S32%20DS%E6%98%AF%EF%BC%9AS32%20Design%20Studio%20for%20Vision%E7%89%88%E6%9C%AC2018.R1%3C%2FP%3E%3CP%3EPC%20OS%20version%3A%20ubuntu%2014.04%2064bits%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E13%3A42%3A02%20****%20%E4%B8%BA%E9%A1%B9%E7%9B%AE%20isp_sonyimx224_csi_dcu%20%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%20A53%20****%3CBR%20%2F%3E%E5%85%A8%E9%83%A8%E5%88%B6%E4%BD%9C-j4%3CBR%20%2F%3E%20make%20--no-print-directory%20%E9%A2%84%E6%9E%84%E5%BB%BA%3CBR%20%2F%3Erm%20-f..%2FA53_gen%2Fsrc%2Fsequencer_srec.c%EF%BC%9Bmake-f..%2FProject_Settings%2FScripts%2Fseq.mkTD%3D%E2%80%9C%2Froot%2FNXP%2FS32DS_Vision_v2018.R1%2Feclipse%2F..%2FCross_Tools%2Fgcc-6.3-arm32-eabi%E2%80%9DVD%3D%E2%80%9C%2Froot%2FNXP%2FS32DS_Vision_v2018.R1%2Feclipse%2F..%2FS32DS%2Fs32v234_sdk%E2%80%9D%3CBR%20%2F%3E%20make%5B2%5D%3A%20dos2unix%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%88%B6%E4%BD%9C--no-print-directory%E4%B8%BB%E6%9E%84%E5%BB%BA%3CBR%20%2F%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2FA53_src%2Fmain.cpp%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9A%E6%A0%87%E5%87%86S32DS%20C%2B%2B%E7%BC%96%E8%AF%91%E5%99%A8%3CBR%20%2F%3Eaarch64-linux-gnu-g%2B%2B%E2%80%9C%40A53_src%2Fmain.args%E2%80%9D-MMD%20-MP%20-MF%E2%80%9CA53_src%2Fmain.d%E2%80%9D-MT%E2%80%9CA53_src%2Fmain.o%E2%80%9D-o%E2%80%9CA53_src%2Fmain.o%E2%80%9D%E2%80%9C..%2FA53_src%2Fmain.cpp%E2%80%9D%3CBR%20%2F%3E%E5%88%B6%E4%BD%9C%5B2%5D%EF%BC%9A***%20%5B..%2FA53_gen%2Fsrc%2Fsequencer_srec.c%5D%E9%94%99%E8%AF%AF%20127%3CBR%20%2F%3E%20make%5B1%5D%3A%20%5Bpre-build%5D%20%E9%94%99%E8%AF%AF%202%20(%E5%B7%B2%E5%BF%BD%E7%95%A5)%3CBR%20%2F%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2FA53_gen%2Fsrc%2Fkmem.c%3CBR%20%2F%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2FA53_gen%2Fsrc%2Fmipi_simple.c%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9A%E6%A0%87%E5%87%86S32DS%20C%E7%BC%96%E8%AF%91%E5%99%A8%3CBR%20%2F%3Eaarch64-linux-gnu-gcc%E2%80%9C%40A53_gen%2Fsrc%2Fkmem.args%E2%80%9D-MMD%20-MP%20-MF%E2%80%9CA53_gen%2Fsrc%2Fkmem.d%E2%80%9D-MT%E2%80%9CA53_gen%2Fsrc%2Fkmem.o%E2%80%9D-o%E2%80%9CA53_gen%2Fsrc%2Fkmem.o%E2%80%9D%20%E2%80%9C..%2FA53_gen%2Fsrc%2Fkmem.c%E2%80%9D%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9A%E6%A0%87%E5%87%86S32DS%20C%E7%BC%96%E8%AF%91%E5%99%A8%3CBR%20%2F%3Eaarch64-linux-gnu-gcc%E2%80%9C%40A53_gen%2Fsrc%2Fkmem.args%E2%80%9D-MMD%20-MP%20-MF%E2%80%9CA53_gen%2Fsrc%2Fmipi_simple.d%E2%80%9D-MT%E2%80%9CA53_gen%2Fsrc%2Fmipi_simple.o%E2%80%9D-o%E2%80%9CA53_gen%2Fsrc%2Fmipi_simple.o%E2%80%9D%E2%80%9C..%2FA53_gen%2Fsrc%2Fmipi_simple.c%E2%80%9D%3CBR%20%2F%3E%E5%AE%8C%E6%88%90%E6%9E%84%E5%BB%BA%EF%BC%9A..%2FA53_gen%2Fsrc%2Fkmem.c%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AE%8C%E6%88%90%E6%9E%84%E5%BB%BA%EF%BC%9A..%2FA53_gen%2Fsrc%2Fmipi_simple.c%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AE%8C%E6%88%90%E6%9E%84%E5%BB%BA%EF%BC%9A..%2FA53_src%2Fmain.cpp%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%EF%BC%9As32ds_isp_sonyimx224_csi_dcu.elf%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9A%E6%A0%87%E5%87%86%20S32DS%20C%2B%2B%20%E9%93%BE%E6%8E%A5%E5%99%A8%3CBR%20%2F%3Eaarch64-linux-gnu-g%2B%2B-o%E2%80%9Cs32ds_isp_sonyimx224_csi_dcu.elf%E2%80%9D%E2%80%9C%40s32ds_isp_sonyimx224_csi_dcu.args%E2%80%9D%3CBR%20%2F%3E.%2FA53_src%2Fmain.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%9CLibsPrepare%EF%BC%88AppContext%26amp%3B%EF%BC%89%E2%80%9D%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20%2Froot%2FworkspaceS32DS.Vision.2018.R1%2Fisp_sonyimx224_csi_dcu%2Fisp_sonyimx224_csi_dcu%2FA53%2F..%2FA53_src%2Fmain.cpp%3A298%EF%BC%9A%E5%AF%B9%E2%80%9Csequencer_srec%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3CBR%20%2F%3E%2Froot%2FworkspaceS32DS.Vision.2018.R1%2Fisp_sonyimx224_csi_dcu%2Fisp_sonyimx224_csi_dcu%2FA53%2F..%2FA53_src%2Fmain.cpp%3A298%EF%BC%9A%E5%AF%B9%E2%80%9Csequencer_srec%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3CBR%20%2F%3Ecollect2%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Ald%20%E8%BF%94%E5%9B%9E%201%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3CBR%20%2F%3E%E4%BD%BF%5B1%5D%EF%BC%9A***%20%5Bs32ds_isp_sonyimx224_csi_dcu.elf%5D%E9%94%99%E8%AF%AF%201%3CBR%20%2F%3E%20make%3A%20***%20%5B%E5%85%A8%E9%83%A8%5D%20%E9%94%99%E8%AF%AF%202%3C%2FP%3E%3CP%3E13%3A42%3A07%20%E6%9E%84%E5%BB%BA%E5%AE%8C%E6%88%90%EF%BC%88%E8%80%97%E6%97%B6%204%20%E7%A7%92%20477%20%E6%AF%AB%E7%A7%92%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F77442iE4CF41FB8F10E1AB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8F%8F%E8%BF%B0%20%E8%B5%84%E6%BA%90%E8%B7%AF%E5%BE%84%20%E4%BD%8D%E7%BD%AE%20%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3ELd%20%E9%94%99%E8%AF%AF%EF%BC%9A2%EF%BC%88%E5%BF%BD%E7%95%A5%EF%BC%89C%2FC%2B%2B%20%E9%97%AE%E9%A2%98%3CBR%20%2F%3ELd%20%E9%94%99%E8%AF%AF%EF%BC%9A2%EF%BC%88%E5%BF%BD%E7%95%A5%EF%BC%89C%2FC%2B%2B%20%E9%97%AE%E9%A2%98%3CBR%20%2F%3ELd%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%AF%B9%E2%80%98sequencer_srec%E2%80%99%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%20isp_sonyimx224_csi_dcu%20C%2FC%2B%2B%20%E9%97%AE%E9%A2%98%3CBR%20%2F%3Emake%3A%20***%20%5B%E5%85%A8%E9%83%A8%5D%20%E9%94%99%E8%AF%AF%202%20isp_sonyimx224_csi_dcu%20C%2FC%2B%2B%20%E9%97%AE%E9%A2%98%3CBR%20%2F%3E%E4%BD%BF%5B1%5D%EF%BC%9A***%20%5Bs32ds_isp_sonyimx224_csi_dcu.elf%5D%E9%94%99%E8%AF%AF%201%20isp_sonyimx224_csi_dcu%20C%2FC%2B%2B%20%E9%97%AE%E9%A2%98%3CBR%20%2F%3E%E5%88%B6%E4%BD%9C%5B2%5D%EF%BC%9A***%20%5B..%2FA53_gen%2Fsrc%2Fsequencer_srec.c%5D%E9%94%99%E8%AF%AF%20127%20isp_sonyimx224_csi_dcu%20C%2FC%2B%2B%20%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F77417i99C221B3BD08A50B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-19-2017 07:44 AM
更新人:
