EXAMPLE: S32k144 UART printf/scanf under FreeRTOS - S32DS
Application based on FreeRTOS S32DS example performs prinf/scanf functionality
in FreeRTOS. Application runs in two modes - standard run-time mode with two tasks
maintained by scheduler and command mode implementing basic memory monitor.
Application was tested with putty terminal (http://www.putty.org/).
Putty serial terminal settings: 115200 8N1, no HW control.
USAGE:
In run-time mode is green LED blinking and on terminal are shown task
counter values.
To enter into COMMAND MODE - press button (next to LED diode). LED light
switches to red and you can enter commands.
Available commands:
F show free heap memory
A set memory address
V print value on address
M set address to main()
P previous mem page
N next mem page
? help
X Exit from command mode
Putty configuration:
Terminal output:
添付
コメント
Hi Jiri Kral
Thanks.
But if I try to use printf/scanf exclusive of freeRTOS.
Is there any other way can reach this feature?
sure - you can use and modify in your project console.c and console.h files. That's where printf/scanf callbacks are implemented.
Jiri
Hi Jiri,
Can you tell me how to config the project that I can use printf to print serial port.
I download your attached project and copy the console.c & console.h, also initialize the LPUART1 and then use printf function in my code, but cannot see serial port print log.
But use the download project you provided it works.
Please advice, thanks.
well, it's hard to say what may be wrong. You can copy/paste the LPUART init from rtos.c . Also don't forget set PTC6 as input and PTC7 output and check uart speed.
Hope it helps.
Jiri
Hi Jiri,
Thanks for relly, I cannot upload attachment file in this thread, can you help on below issue:
https://community.nxp.com/message/1029038
for some reason your link is not accessible for me. Did you create your thread in https://community.nxp.com/community/s32/s32ds  community space?
Jiri
Yes, under S32K, my topic named:
Printf in FreeRTOS
Hi Jiri,
Try your project, printf function is ok, but cannot type in command in command mode?
I don't konow why, I am using the S32K144 EVB and use usb to serial port cable.
what terminal you are using? In RealTerm - RealTerm: Serial/TCP Terminal - Browse /Realterm/2.0.0.70 at SourceForge.net
is input working okay.
Jiri
I use putty:
If I remember it correctly - in putty you need to setup the end character. So - you can give a chance to RealTerm - this one works out of box.
Jiri
I tried fresh Putty install, and for me it also works out of the box:
Here is my putty settings:
Jiri
Thanks Jiri,
Maybe there are some hardware or connection issue in my side, I will show your the capture of my board and serial line connection.
   I can also compile using your project and pringf output is ok.I copied your console.c and.h files into my project. After adding the reference path, you can compile.But printf can't output, the code card dies here.
Hi Jiri,
Thanks for providing this sample code. With some modification, now I can use printf on S32K118.
I put scanf() in a task, and I found the task have high percentage of run time loading. That's because the __read_console traps in the LPUART_DRV_GetReceiveStatus if there is no input data.
int_t __read_console(__file_handle handleuchar_t * buffersize_t * count)
  uint32_t bytesRemain;
  bool MsgDone=false;
  uchar_t new_lin[]={"\n"};
  int i=0;
  while (MsgDone==false)
    LPUART_DRV_ReceiveData(INST_LPUART1, &buffer[i], 1);
    while(LPUART_DRV_GetReceiveStatus(INST_LPUART1, &bytesRemain) != STATUS_SUCCESS);
Thus, I add some delay in the while loop or use LPUART_DRV_ReceiveDataBlocking with portMax_DELAY, then the run time loading becomes normal. I was wondering if this a correct method. If so, I think this could be a reference for others.
  bool MsgDone=false;
  int i=0;
    // LPUART_DRV_ReceiveData(INST_LPUART1, &buffer[i], 1);
    // while(LPUART_DRV_GetReceiveStatus(INST_LPUART1, &bytesRemain) != STATUS_SUCCESS)
    //    vTaskDelay(5);
    LPUART_DRV_ReceiveDataBlocking(INST_LPUART1, &buffer[i], 1, portMAX_DELAY);
Jimmy
Hi, I use your console.h and console.c file in my project, but get that problem, How can i do this? thank you very much.
if I use another config, still have error,I don't know how to slove this erroe,  Thank you!
i creat three task in this demo, but it doesn't work, seems all hold on, can you check it ?
@jiri_kral
static void prvQueueTestTask( void *pvParameters )
unsigned long ulReceivedValue;
/* Casting pvParameters to void because it is unused */
(void)pvParameters;
int i = 0;
printf("first prvQueueTestTask=%d\n",i);
for( ;; )
/* Wait until something arrives in the queue - this task will block
indefinitely provided INCLUDE_vTaskSuspend is set to 1 in
FreeRTOSConfig.h. */
//xQueueReceive( xQueue, &ulReceivedValue, portMAX_DELAY );
printf("prvQueueTestTask=%d\n",i);
/*  To get here something must have been received from the queue, but
is it the expected value?  If it is, toggle the LED. */
vTaskDelay(pdMS_TO_TICKS(10));
void rtos_start( void )
/* Configure the NVIC, LED outputs and button inputs. */
prvSetupHardware();
/* Create the queue. */
xQueue = xQueueCreate( mainQUEUE_LENGTH, sizeof( unsigned long ) );
if( xQueue != NULL )
/* Start the two tasks as described in the comments at the top of this
file. */
xTaskCreate( prvQueueReceiveTask, "RX", configMINIMAL_STACK_SIZE, NULL, mainQUEUE_RECEIVE_TASK_PRIORITY, NULL );
xTaskCreate( prvQueueSendTask, "TX", configMINIMAL_STACK_SIZE, NULL, mainQUEUE_SEND_TASK_PRIORITY, NULL );
xTaskCreate( prvQueueTestTask, "TEST", configMINIMAL_STACK_SIZE, NULL, 3, NULL );
/* Create the software timer that is responsible for turning off the LED
if the button is not pushed within 5000ms, as described at the top of
this file. */
xButtonLEDTimer = xTimerCreate( "ButtonLEDTimer", /* A text name, purely to help debugging. */
mainBUTTON_LED_TIMER_PERIOD_MS, /* The timer period, in this case 5000ms (5s). */
pdFALSE, /* This is a one shot timer, so xAutoReload is set to pdFALSE. */
( void * ) 0, /* The ID is not used, so can be set to anything. */
prvButtonLEDTimerCallback /* The callback function that switches the LED off. */
/* Start the tasks and timer running. */
vTaskStartScheduler();
/* If all is well, the scheduler will now be running, and the following line
will never be reached.  If the following line does execute, then there was
insufficient FreeRTOS heap memory available for the idle and/or timer tasks
to be created.  See the memory management section on the FreeRTOS web site
for more details. */
for( ;; );
i resolved it, thanks
Anonymous
Hi! I am learning and using NXP S32k148 board from scratch.  I have to connect ESP32 Wi-Fi module to NXP board and simply trans receive "HELLO" message using UART. How to do that? Please help me out. I cannot see any recourse about this so need your help.
%3CLINGO-SUB%20id%3D%22lingo-sub-1122496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8B%3A%20FreeRTOS%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AES32k144%20UART%20printf%2Fscanf%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFreeRTOS%20S32DS%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81FreeRTOS%E3%81%A7prinf%2Fscanf%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF2%E3%81%A4%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A62%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E6%A8%99%E6%BA%96%E5%AE%9F%E8%A1%8C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%80%81%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81PuTTY%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%EF%BC%88%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.putty.org%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.putty.org%2F%3C%2FA%3E%3CSPAN%3E%EF%BC%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPutty%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%AB%AF%E6%9C%AB%E8%A8%AD%E5%AE%9A%EF%BC%9A115200%208N1%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%B3%95%EF%BC%9A%3CBR%20%2F%3E%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E7%B7%91%E8%89%B2%E3%81%AELED%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%97%E3%80%81%3CBR%20%2F%3E%E7%AB%AF%E6%9C%AB%E3%81%AB%E3%81%AF%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E5%80%A4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%EF%BC%88LED%E3%83%80%E3%82%A4%E3%82%AA%E3%83%BC%E3%83%89%E3%81%AE%E6%A8%AA%EF%BC%89%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82LED%20%E3%83%A9%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E3%81%8C%E8%B5%A4%E8%89%B2%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8A%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%9A%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EF%20%E7%A9%BA%E3%81%8D%E3%83%92%E3%83%BC%E3%83%97%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3EA%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3EV%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%80%A4%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3EM%20main()%20%E3%81%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3EP%20%E5%89%8D%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3EN%20%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%EF%BC%9F%E3%83%98%E3%83%AB%E3%83%97%3CBR%20%2F%3EX%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPuTTY%E3%81%AE%E8%A8%AD%E5%AE%9A%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20466px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F34147i5CDCCBC336589EEC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20466px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F32591iD0E19BAB08E045A7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E5%87%BA%E5%8A%9B%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22putty_2017-09-21_10-12-40.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22putty_2017-09-21_10-12-40.png%22%20style%3D%22width%3A%20654px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F32543iBF247725205FD51C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22putty_2017-09-21_10-12-40.png%22%20alt%3D%22putty_2017-09-21_10-12-40.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1122496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFreeRTOS%20S32DS%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81FreeRTOS%E3%81%A7prinf%2Fscanf%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF2%E3%81%A4%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A62%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E6%A8%99%E6%BA%96%E5%AE%9F%E8%A1%8C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%80%81%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81PuTTY%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%EF%BC%88%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.putty.org%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.putty.org%2F%3C%2FA%3E%3CSPAN%3E%EF%BC%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPutty%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%AB%AF%E6%9C%AB%E8%A8%AD%E5%AE%9A%EF%BC%9A115200%208N1%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%B3%95%EF%BC%9A%3CBR%20%2F%3E%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E7%B7%91%E8%89%B2%E3%81%AELED%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%97%E3%80%81%3CBR%20%2F%3E%E7%AB%AF%E6%9C%AB%E3%81%AB%E3%81%AF%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E5%80%A4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%EF%BC%88LED%E3%83%80%E3%82%A4%E3%82%AA%E3%83%BC%E3%83%89%E3%81%AE%E6%A8%AA%EF%BC%89%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82LED%20%E3%83%A9%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E3%81%8C%E8%B5%A4%E8%89%B2%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8A%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%9A%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EF%20%E7%A9%BA%E3%81%8D%E3%83%92%E3%83%BC%E3%83%97%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3EA%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3EV%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%80%A4%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3EM%20main()%20%E3%81%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3EP%20%E5%89%8D%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3EN%20%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%EF%BC%9F%E3%83%98%E3%83%AB%E3%83%97%3CBR%20%2F%3EX%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPuTTY%E3%81%AE%E8%A8%AD%E5%AE%9A%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FCD8FDF836FCE0DCD759843D0E68C0057%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FCD8FDF836FCE0DCD759843D0E68C0057%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E5%87%BA%E5%8A%9B%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FCD8FDF836FCE0DCD759843D0E68C0057%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81NXP%20S32K148%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E5%AD%A6%E3%81%B3%E3%81%AA%E3%81%8C%E3%82%89%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82ESP32%20Wi-Fi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92NXP%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81UART%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%8CHELLO%E3%80%8D%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%8C%E3%81%88%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%87%E6%96%99%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1664122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1664122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1664088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1664088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A73%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%9B%E3%81%9A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E4%BF%9D%E7%95%99%E7%8A%B6%E6%85%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F159987%22%20target%3D%22_blank%22%3E%40jiri_kral%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bug2.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bug2.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F109763iFB8567B89BCA0430%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22bug2.JPG%22%20alt%3D%22bug2.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%82%84%E3%81%AF%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bug.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bug.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F109752i59A6FF63B13A1D9E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22bug.JPG%22%20alt%3D%22bug.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ds.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ds.JPG%22%20style%3D%22width%3A%20727px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F109779i8F5921AD6E9632F6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ds.JPG%22%20alt%3D%22ds.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20console.h%20%E3%81%A8%20console.c%20%E3%82%92%E8%87%AA%E5%88%86%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiri%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%B0%91%E3%81%97%E4%BF%AE%E6%AD%A3%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81S32K118%E3%81%A7printf%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%20scanf()%20%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AE%E5%89%B2%E5%90%88%E3%81%8C%E9%AB%98%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81__read_console%20%E3%81%8C%20LPUART_DRV_GetReceiveStatus%20%E3%81%A7%E3%83%88%E3%83%A9%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%234ec9b0%3B%22%3Eint_t%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23dcdcaa%3B%22%3E__read_console%3C%2FSPAN%3E%3CSPAN%3E(__file_handle%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ehandle%3C%2FSPAN%3E%3CSPAN%3E%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%234ec9b0%3B%22%3Euchar_t%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ebuffer%3C%2FSPAN%3E%3CSPAN%3E%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Esize_t%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ecount%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3BbytesRemain%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Ebool%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3BMsgDone%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%234ec9b0%3B%22%3Euchar_t%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3Bnew_lin%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3E%5B%5D%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ce9178%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d7ba7d%3B%22%3E%5Cn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ce9178%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3Bi%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23b5cea8%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c586c0%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B(MsgDone%3C%2FSPAN%3E%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23dcdcaa%3B%22%3ELPUART_DRV_ReceiveData%3C%2FSPAN%3E%3CSPAN%3E(INST_LPUART1%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ebuffer%3C%2FSPAN%3E%3CSPAN%3E%5Bi%5D%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23b5cea8%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c586c0%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23dcdcaa%3B%22%3ELPUART_DRV_GetReceiveStatus%3C%2FSPAN%3E%3CSPAN%3E(INST_LPUART1%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3EbytesRemain)%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3BSTATUS_SUCCESS)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81while%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E9%81%85%E5%BB%B6%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81portMax_DELAY%E3%81%A7LPUART_DRV_ReceiveDataBlocking%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E6%96%B9%E6%B3%95%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%82%82%E5%8F%82%E8%80%83%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%234ec9b0%3B%22%3Eint_t%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23dcdcaa%3B%22%3E__read_console%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E(__file_handle%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ehandle%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%234ec9b0%3B%22%3Euchar_t%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ebuffer%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Esize_t%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ecount%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Euint32_t%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3BbytesRemain%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Ebool%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3BMsgDone%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%234ec9b0%3B%22%3Euchar_t%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3Bnew_lin%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3E%5B%5D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ce9178%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d7ba7d%3B%22%3E%5Cn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ce9178%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3Bi%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23b5cea8%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c586c0%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B(MsgDone%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23569cd6%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%236a9955%3B%22%3E%2F%2F%26nbsp%3BLPUART_DRV_ReceiveData(INST_LPUART1%2C%26nbsp%3B%26amp%3Bbuffer%5Bi%5D%2C%26nbsp%3B1)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%236a9955%3B%22%3E%2F%2F%26nbsp%3Bwhile(LPUART_DRV_GetReceiveStatus(INST_LPUART1%2C%26nbsp%3B%26amp%3BbytesRemain)%26nbsp%3B!%3D%26nbsp%3BSTATUS_SUCCESS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%236a9955%3B%22%3E%2F%2F%26nbsp%3B%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%236a9955%3B%22%3E%2F%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BvTaskDelay(5)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%236a9955%3B%22%3E%2F%2F%26nbsp%3B%26nbsp%3B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23dcdcaa%3B%22%3ELPUART_DRV_ReceiveDataBlocking%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E(INST_LPUART1%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%239cdcfe%3B%22%3Ebuffer%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%5Bi%5D%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23b5cea8%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23d4d4d4%3B%22%3E%2C%26nbsp%3BportMAX_DELAY)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%9F%E3%83%BC%3C%2FP%3E%3CDIV%20style%3D%22color%3A%20%23d4d4d4%3B%20background-color%3A%20%231e1e1e%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22font-weight%3A%20normal%3B%22%3E%3CDIV%20style%3D%22background-color%3A%20%231e1e1e%3B%20font-weight%3A%20normal%3B%22%3E%3CDIV%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-0%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3EHi%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-0%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%97%E3%80%81printf%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-1%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3Econsole.c%E3%81%A8.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%82%E7%85%A7%E3%83%91%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-2%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81printf%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%93%E3%81%93%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-0%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3EHi%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-0%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%97%E3%80%81printf%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-1%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3Econsole.c%E3%81%A8.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%82%E7%85%A7%E3%83%91%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-2%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81printf%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%93%E3%81%93%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-0%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%97%E3%80%81printf%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-1%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3Econsole.c%E3%81%A8.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%82%E7%85%A7%E3%83%91%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20data-group%3D%220-2%22%20data-v-4c8ee738%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f7f8fa%3B%20font-size%3A%2014px%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81printf%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%93%E3%81%93%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJiri%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97%E3%81%8B%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%84%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%A9%E3%82%A4%E3%83%B3%E6%8E%A5%E7%B6%9A%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%92%E3%81%8A%E8%A6%8B%E3%81%9B%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPuTTY%E3%81%AE%E6%96%B0%E8%A6%8F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20661px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64670iBDEE6D1084BD0B43%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%8C%E7%A7%81%E3%81%AEPuTTY%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20452px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64671i2D16DD6686564BDB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJiri%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E8%A8%98%E6%86%B6%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81PuTTY%20%E3%81%A7%E3%81%AF%E7%B5%82%E4%BA%86%E6%96%87%E5%AD%97%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81RealTerm%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E4%BE%A1%E5%80%A4%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%90%E3%81%AB%E4%BD%BF%E3%81%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%AA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFPuTTY%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20612px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64654i5392FB751C33A47A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FRealTerm%E3%81%AE%E5%A0%B4%E5%90%88%20-%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsourceforge.net%2Fprojects%2Frealterm%2Ffiles%2FRealterm%2F2.0.0.70%2F%22%20title%3D%22https%3A%2F%2Fsourceforge.net%2Fprojects%2Frealterm%2Ffiles%2FRealterm%2F2.0.0.70%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ERealTerm%3A%20Serial%2FTCP%20Terminal%20-%20Browse%20%2FRealterm%2F2.0.0.70%20at%20SourceForge.net%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%AA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiri%2C%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82printf%20%E9%96%A2%E6%95%B0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%90%86%E7%94%B1%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81S32K144%20EVB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81USB-%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81S32K%E9%96%A2%E9%80%A3%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CH1%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%202rem%3B%22%20id%3D%22toc-hId-382396407%22%20id%3D%22toc-hId-1303233368%22%3EFreeRTOS%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BPrintf%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fs32%2Fs32ds%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fs32%2Fs32ds%3C%2FA%3E%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%AA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiri%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AB%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%AF%BE%E5%87%A6%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F1029038%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F1029038%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%81%AD%E3%80%81%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%81%AF%E3%81%AF%E3%81%A3%E3%81%8D%E3%82%8A%E3%81%A8%E3%81%AF%E8%A8%80%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82rtos.c%20%E3%81%8B%E3%82%89%20LPUART%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%EF%BC%86%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81PTC6%E3%82%92%E5%85%A5%E5%8A%9B%E3%80%81PTC7%E5%87%BA%E5%8A%9B%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81UART%E9%80%9F%E5%BA%A6%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F62540i472427A8E7F279F6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%AA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiri%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eprintf%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%80%81console.c%E3%81%A8%20console.h%20%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%20LPUART1%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%A7%20printf%20%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%AD%E3%82%B0%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%20console.c%20%E3%81%8A%E3%82%88%E3%81%B3%20console.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82printf%2Fscanf%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJiri%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%3A%20S32k144%20UART%20printf%2Fscanf%20under%20FreeRTOS%20-%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%AA%E3%83%BB%E3%82%AF%E3%83%A9%E3%83%AB%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFreeRTOS%20%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%9A%E3%81%AB%20printf%2Fscanf%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎09-08-2017 04:15 AM
更新者:
