eeprom does retains the data afterresetMM9Z1I638
1,631 次查看
lahcenmejjad
I am using the sample code provide by Freescale(NXP) in the project KT9Z1-638-REFAPP.
The Eeprom erased when I reset or power off  the board.
I  am using the function, EEPROM_WriteCalibValue as it is.
best regards
1,573 次查看
danielmartynek
If the EEPROM is erased, there must be a function that erases it.
Have you tried to halt the execution just after POR, check the EEPROM and step the code?
BR, Daniel
1,574 次查看
danielmartynek
BR, Daniel
1,573 次查看
lahcenmejjad
Hello Daniel,
thank you for your response,
I did step by step , but I was using library  from NXP ( executable code), so I could not go through their code.when I replaced the CPU, and It seems every thing is working fine  so far.
I think the problem is resolved !!
