Internal temperature sensor MM9Z1J638
1,827件の閲覧回数
Boris_Bloxsberg
I`ve got some questions regarding the internal temperature sensor.
Is there a detailed description of the regsiters  B_COMP_ITO, B_COMP_ITG, B_COMP_ETG avialable (e.g. Calculation)?
Are the trim values induvidual calculated for every MCU?
タグ(2)
1,810件の閲覧回数
StanoA
Hello Boris,
The all about system calibration and how to use the calibration values stored in FLASH for each chip is in AN12301:
https://www.nxp.com/docs/en/application-note/AN12301.pdf
I hope it could help you solve your task.
Stano.
1,804件の閲覧回数
Boris_Bloxsberg
thx.
1,811件の閲覧回数
StanoA
Hello Boris,
Stano.
