Hi lama,
From your commnent, I imagine the following signal path/connection.
My understanding summary:
1. SEI/CLI instructions act for CCR I-bit
2. I-bit set/clear status signal is connected to INT modules
3. I-bit set/clear status signal and each peripheral interrupt signal are muxed in INT modules
INT module judges Interrupt release or pending based on these signals and register settings
(e.g. PRIOLVL[2:0] in S12Z INT module)
4. Output signals are connected to CPU
Is my understanding correct?
If not, could you point out the wrong point/description?
Ikki
