I'm afraid that hard electromagnetic interference can cause more issues than just the watchdog failure. But this is application dependent.
However, I assume, that you mean the external watchdog.
The useful points were discussed in the community thread below.
https://community.nxp.com/message/816291?commentID=816291
I'm not sure which MCU you use. If you have a device from MagniV family I recommend you to look at the Hardware Design Guidelines. There is the section "EMI/EMC and ESD Considerations for Layout"
I hope it helps.
Diana
