Compile e5500 kernel with little endian ?
3,668 次查看
yusufalti333
Hello community,
I want to compile little endian linux kernel for t1042d4rdb-64b ( powerpc e5500 family) but that option does not exists in menuconfig. There is only "Build big endian kernel" in "Endianness Selection" section. How can I do this ?
Thanks.
3,537 次查看
ufedor
The requested option is not supported by NXP SDK.
3,538 次查看
ufedor
3,537 次查看
yusufalti333
I have a driver which supports little endian. So this means I am unable to use that forever :smileysad:
3,537 次查看
ufedor
Please understand - little-endian kernel building and its further operation never was tested.
Converting the driver to big-endian is a simpler task.
