We are using marvell swtich with ls1088a. How to make DSA cpu port configuration in device tree ? Should the CONFIG_FSL_DPAA2_MAC_NETDEVS be active in kernel ? Is there a sample application with DSA ?
thanks for the answer. This examples are not compatible with dpaa2. The ethernet property of the dsa cpu port needs to specify a node. DPNI can't be chosen for this node in the device tree. How to make DSA cpu port configuration in device tree ?
Please refer to dsa dts definition in Documentation/devicetree/bindings/net/dsa/dsa.txt in Linux Kernel source .
Hello Ferdi Tekce,
Please refer to https://community.nxp.com/message/469496?commentID=469496#comment-469496 for DSA configuration in the device tree.
Please refer to https://community.nxp.com/message/573431
Yiping
