40G network performance on LX2160A-RDB
7,318 次查看
Kassany
Having performed some network performance tests with iperf3, it can be seen that the maximum connection capacity is not reached.
UDP
[  5]   0.00-1.00   sec   673 MBytes  5.65 Gbits/sec  524771
[  5]   1.00-2.00   sec   678 MBytes  5.69 Gbits/sec  528683
[  5]   2.00-3.00   sec   677 MBytes  5.68 Gbits/sec  527809
[  5]   3.00-4.00   sec   690 MBytes  5.79 Gbits/sec  537840
[  5]   4.00-5.00   sec   699 MBytes  5.87 Gbits/sec  545084
[  5]   5.00-6.00   sec   695 MBytes  5.83 Gbits/sec  542207
[  5]   6.00-7.00   sec   680 MBytes  5.70 Gbits/sec  529956
[  5]   7.00-8.00   sec   665 MBytes  5.58 Gbits/sec  518615
[  5]   8.00-9.00   sec   653 MBytes  5.47 Gbits/sec  508780
[  5]   9.00-10.00  sec   641 MBytes  5.38 Gbits/sec  499949
[ ID] Interval           Transfer     Bitrate         Jitter    Lost/Total Datagrams
[  5]   0.00-10.00  sec  6.59 GBytes  5.66 Gbits/sec  0.000 ms  0/5263694 (0%)  sender
[  5]   0.00-10.64  sec  38.1 MBytes  30.0 Mbits/sec  0.242 ms  5233880/5263562 (99%)  receiver
TCP
 ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  1.18 MBytes  9.93 Mbits/sec    0    403 KBytes
[  5]   1.00-2.00   sec  3.88 MBytes  32.5 Mbits/sec  141    465 KBytes
[  5]   2.00-3.00   sec  4.75 MBytes  39.8 Mbits/sec    0    520 KBytes
[  5]   3.00-4.00   sec  5.25 MBytes  44.0 Mbits/sec    1    389 KBytes
[  5]   4.00-5.00   sec  3.75 MBytes  31.5 Mbits/sec    1    298 KBytes
[  5]   5.00-6.00   sec  2.88 MBytes  24.1 Mbits/sec    0    328 KBytes
[  5]   6.00-7.00   sec  3.00 MBytes  25.2 Mbits/sec    0    345 KBytes
[  5]   7.00-8.00   sec  3.25 MBytes  27.3 Mbits/sec    0    355 KBytes
[  5]   8.00-9.00   sec  3.38 MBytes  28.3 Mbits/sec    0    357 KBytes
[  5]   9.00-10.00  sec  3.62 MBytes  30.4 Mbits/sec    0    357 KBytes
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.00  sec  34.9 MBytes  29.3 Mbits/sec  143             sender
[  5]   0.00-10.19  sec  34.1 MBytes  28.0 Mbits/sec                  receiver
Some reconfigurations of the LK were made according to the recommendations mentioned by @yipingwang in another similar thread[1].
BR,
Matheus C. França
7,182 次查看
yipingwang
You could use DPDK.
Please refer to dpdk ipsecgw performance.
  LSDK20.12 kernel 5.4
name Framesize Throughput(Kpps) Throughput(Mbps)
dpdk_ipsecgw_caam_offload_50g_16c_perf 82 23,953 19,546
408 13,967 47,825
1,442 4,275 50,000
6 回复数
7,271 次查看
yipingwang
I got similar iperf performance result as the following with LSDK 21.08 default software environment and two lx2160ardb boards connecting together.  Is your user case termination traffic instead of forwarding?
root@localhost:/# iperf -c 100.1.1.64 -P 16 -t 30
Client connecting to 100.1.1.64, TCP port 5001
TCP window size: 442 KByte (default)
[ 4] local 100.1.1.65 port 44980 connected with 100.1.1.64 port 5001
[ 5] local 100.1.1.65 port 44982 connected with 100.1.1.64 port 5001
[ 3] local 100.1.1.65 port 44978 connected with 100.1.1.64 port 5001
[ 6] local 100.1.1.65 port 44984 connected with 100.1.1.64 port 5001
[ 7] local 100.1.1.65 port 44986 connected with 100.1.1.64 port 5001
[ 8] local 100.1.1.65 port 44988 connected with 100.1.1.64 port 5001
[ 12] local 100.1.1.65 port 44996 connected with 100.1.1.64 port 5001
[ 9] local 100.1.1.65 port 44990 connected with 100.1.1.64 port 5001
[ 10] local 100.1.1.65 port 44992 connected with 100.1.1.64 port 5001
[ 11] local 100.1.1.65 port 44994 connected with 100.1.1.64 port 5001
[ 13] local 100.1.1.65 port 44998 connected with 100.1.1.64 port 5001
[ 14] local 100.1.1.65 port 45000 connected with 100.1.1.64 port 5001
[ 15] local 100.1.1.65 port 45002 connected with 100.1.1.64 port 5001
[ 16] local 100.1.1.65 port 45004 connected with 100.1.1.64 port 5001
[ 17] local 100.1.1.65 port 45006 connected with 100.1.1.64 port 5001
[ 18] local 100.1.1.65 port 45008 connected with 100.1.1.64 port 5001
[ ID] Interval Transfer Bandwidth
[ 7] 0.0-30.0 sec 1.29 GBytes 369 Mbits/sec
[ 12] 0.0-30.0 sec 1.26 GBytes 362 Mbits/sec
[ 11] 0.0-30.0 sec 1.21 GBytes 346 Mbits/sec
[ 14] 0.0-30.0 sec 1.24 GBytes 355 Mbits/sec
[ 16] 0.0-30.0 sec 1.27 GBytes 364 Mbits/sec
[ 4] 0.0-30.0 sec 1.23 GBytes 352 Mbits/sec
[ 5] 0.0-30.0 sec 1.27 GBytes 362 Mbits/sec
[ 9] 0.0-30.0 sec 1.24 GBytes 356 Mbits/sec
[ 13] 0.0-30.0 sec 1.28 GBytes 365 Mbits/sec
[ 15] 0.0-30.0 sec 1.25 GBytes 357 Mbits/sec
[ 3] 0.0-30.1 sec 1.25 GBytes 356 Mbits/sec
[ 6] 0.0-30.0 sec 1.31 GBytes 376 Mbits/sec
[ 10] 0.0-30.1 sec 1.28 GBytes 365 Mbits/sec
[ 17] 0.0-30.0 sec 1.23 GBytes 353 Mbits/sec
[ 18] 0.0-30.0 sec 1.24 GBytes 354 Mbits/sec
[ 8] 0.0-30.1 sec 1.28 GBytes 366 Mbits/sec
[SUM] 0.0-30.1 sec 20.1 GBytes 5.75 Gbits/sec
root@localhost:/# iperf -c 100.1.1.64 -P 16 -t 30 -u -b 40G
Client connecting to 100.1.1.64, UDP port 5001
Sending 1470 byte datagrams, IPG target: 0.27 us (kalman adjust)
UDP buffer size: 208 KByte (default)
[ 3] local 100.1.1.65 port 47092 connected with 100.1.1.64 port 5001
[ 4] local 100.1.1.65 port 51398 connected with 100.1.1.64 port 5001
[ 5] local 100.1.1.65 port 51049 connected with 100.1.1.64 port 5001
[ 6] local 100.1.1.65 port 43814 connected with 100.1.1.64 port 5001
[ 7] local 100.1.1.65 port 45999 connected with 100.1.1.64 port 5001
[ 8] local 100.1.1.65 port 57700 connected with 100.1.1.64 port 5001
[ 9] local 100.1.1.65 port 60702 connected with 100.1.1.64 port 5001
[ 10] local 100.1.1.65 port 43959 connected with 100.1.1.64 port 5001
[ 11] local 100.1.1.65 port 39367 connected with 100.1.1.64 port 5001
[ 12] local 100.1.1.65 port 52498 connected with 100.1.1.64 port 5001
[ 13] local 100.1.1.65 port 46112 connected with 100.1.1.64 port 5001
[ 14] local 100.1.1.65 port 48562 connected with 100.1.1.64 port 5001
[ 15] local 100.1.1.65 port 33950 connected with 100.1.1.64 port 5001
[ 16] local 100.1.1.65 port 37260 connected with 100.1.1.64 port 5001
[ 17] local 100.1.1.65 port 35469 connected with 100.1.1.64 port 5001
[ 18] local 100.1.1.65 port 32931 connected with 100.1.1.64 port 5001
[ 5] 0.0-30.2 sec 275 MBytes 76.3 Mbits/sec
[ 5] Sent 196141 datagrams
[ 5] Server Report:
[ 5] 0.0-30.2 sec 192 KBytes 51.9 Kbits/sec 11.167 ms 3101/ 0 (inf%)
[ 10] 0.0-30.2 sec 277 MBytes 77.0 Mbits/sec
[ 10] Sent 197856 datagrams
[ 12] 0.0-30.2 sec 278 MBytes 77.1 Mbits/sec
[ 12] Sent 198121 datagrams
[ 14] 0.0-30.2 sec 276 MBytes 76.6 Mbits/sec
[ 14] Sent 196964 datagrams
[ 12] Server Report:
[ 12] 0.0-30.2 sec 193 KBytes 52.4 Kbits/sec 14.995 ms 3719/ 0 (inf%)
[ 10] Server Report:
[ 10] 0.0-30.2 sec 193 KBytes 52.4 Kbits/sec 20.850 ms 2843/ 0 (inf%)
[ 14] Server Report:
[ 14] 0.0-30.2 sec 192 KBytes 52.1 Kbits/sec 6.310 ms 7829/ 0 (inf%)
[ 6] 0.0-30.2 sec 279 MBytes 77.3 Mbits/sec
[ 6] Sent 198680 datagrams
[ 7] 0.0-30.2 sec 279 MBytes 77.3 Mbits/sec
[ 7] Sent 198676 datagrams
[ 8] 0.0-30.2 sec 275 MBytes 76.2 Mbits/sec
[ 8] Sent 195864 datagrams
[ 16] 0.0-30.2 sec 272 MBytes 75.5 Mbits/sec
[ 16] Sent 194226 datagrams
[ 7] Server Report:
[ 7] 0.0-30.2 sec 194 KBytes 52.6 Kbits/sec 14.559 ms 2173/ 0 (inf%)
[ 8] Server Report:
[ 8] 0.0-30.2 sec 191 KBytes 51.8 Kbits/sec 12.627 ms 831/ 0 (inf%)
[ 6] Server Report:
[ 6] 0.0-30.2 sec 194 KBytes 52.6 Kbits/sec 14.019 ms 8185/ 0 (inf%)
[ 16] Server Report:
[ 16] 0.0-30.2 sec 190 KBytes 51.4 Kbits/sec 0.001 ms 4134/ 0 (inf%)
[ 3] 0.0-30.2 sec 275 MBytes 76.4 Mbits/sec
[ 3] Sent 196386 datagrams
[ 13] 0.0-30.2 sec 273 MBytes 75.8 Mbits/sec
[ 13] Sent 194996 datagrams
[ 17] 0.0-30.2 sec 274 MBytes 75.9 Mbits/sec
[ 17] Sent 195257 datagrams
[ 13] Server Report:
[ 13] 0.0-30.2 sec 190 KBytes 51.6 Kbits/sec 9.668 ms 7045/ 0 (inf%)
[ 3] Server Report:
[ 3] 0.0-30.2 sec 192 KBytes 52.0 Kbits/sec 6.817 ms 2735/ 0 (inf%)
[ 17] Server Report:
[ 17] 0.0-30.2 sec 191 KBytes 51.7 Kbits/sec 0.446 ms 9778/ 0 (inf%)
[ 11] 0.0-30.2 sec 277 MBytes 76.7 Mbits/sec
[ 11] Sent 197250 datagrams
[ 15] 0.0-30.2 sec 275 MBytes 76.3 Mbits/sec
[ 15] Sent 196217 datagrams
[ 18] 0.0-30.2 sec 274 MBytes 76.0 Mbits/sec
[ 18] Sent 195509 datagrams
[ 18] Server Report:
[ 18] 0.0-30.2 sec 191 KBytes 51.7 Kbits/sec 3.367 ms 6324/ 0 (inf%)
[ 11] Server Report:
[ 11] 0.0-30.2 sec 193 KBytes 52.2 Kbits/sec 7.802 ms 4433/ 0 (inf%)
[ 15] Server Report:
[ 15] 0.0-30.2 sec 192 KBytes 51.9 Kbits/sec 3.930 ms 2006/ 0 (inf%)
[ 4] 0.0-30.2 sec 277 MBytes 76.8 Mbits/sec
[ 4] Sent 197401 datagrams
[ 9] 0.0-30.2 sec 279 MBytes 77.3 Mbits/sec
[ 9] Sent 198661 datagrams
[SUM] 0.0-30.2 sec 4.31 GBytes 1.22 Gbits/sec
[SUM] Sent 3148205 datagrams
7,261 次查看
Kassany
Hi @yipingwang. Appreciate the feedback!
My work is with terminating traffic and not forwarding. However, I would like to know if it is possible to get the 40G on the QSFP port?
BR,
Matheus C. França
7,180 次查看
yipingwang
Please specify "-P 8", please refer to the following iperf result provided by the testing team.
7,161 次查看
yipingwang
This is the result of netperf, the result is about 35.6Gbps.
7,109 次查看
Kassany
Thanks again @yipingwang, I have found a slight confusion of understanding about iperf3 and iperf2 frustrating the results.
Based on your tests with netperf and iperf2, the results are similar and expected.
BR,
Matheus C. França
7,183 次查看
yipingwang
You could use DPDK.
408 13,967 47,825
1,442 4,275 50,000
