about "code for component has not been generate yet"
1,904 次查看
LiKe
I use MQX3.8 add AD follow <<CW for Microcotrollers v10.x and MQX>> page 139. but I check AD and view source code.
the cw10.x POP "code for component has not been generate yet",why? bye the way, I use windows 7
标记 (1)
1,694 次查看
ProcessorExpert
Senior Contributor III
Could you please write more details on what CodeWarrior version are you using?
The Processor Expert code can be generated using the project pop-up menu command "Generate Processor Expert code" or you can use the icon (see attachment) in Processor Expert project panel. Processor Expert project panel can be opened using the command Window > Show view > Other... , select Processor Expert / Project panel.
best regards
Petr Hradsky
Processor Expert Support Team
1,695 次查看
ProcessorExpert
best regards
Petr Hradsky
