Read/Write Eeprom in HCS12X using Processor Expert
parthdh96
I am using Code Warrier 5.1 and initialized timers and ADCs using processor expert. I am facing problem with writing data in eeprom, I need some guidance with read/writ in eeprom.
Thank you
soledad
 In order to use processor Expert.
1. Create a project for HCS12 using Processor Expert and add a bean IntEEPROM to the application.
2. Configure the bean according to what you want to do,
3. let Processor Expert generate code.
In addition, please check the application note AN2204, this appnote provides sample code for reading/writing to EEPROM.
https://www.nxp.com/docs/en/application-note/AN2204.pdf
I hope this helps,
Have a nice day
Soledad
