How to recompile modified RCW file for LS1043ARDB
4,926件の閲覧回数
dana_xiong
Hi ,
I modified RCW .cfg file under /LSDK_1906/flexbuild_lsdk/packages/firmware/u-boot/board/freescale/ls1043ardb folder
modify ls1043ardb_rcw_sd.cfg file
use "flex-builder -i mkfw -m ls1043ardb -b sd" command to recompile
find the modification faile
How to compile the modify .cfg file ?
Thanks & Best Regards !
Dana Xiong
タグ(1)
4 返答(返信)
4,727件の閲覧回数
yipingwang
Hello Dana Xiong,
You could generate SD boot RCW with rcw package.
$ flex-builder -c rcw -m ls1043ardb
Please modify packages/firmware/rcw/ls1043ardb/RR_FQPP_1455/rcw_*_sdboot.rcw according to your requirement.
Then run "flex-builder -c rcw -m ls1043ardb" again, and get packages/firmware/rcw/ls1043ardb/RR_FQPP_1455/rcw_*_sdboot.bin
Please run the command "xxd rcw_*_sdboot.bin" to display rcw binary file.
Then modify packages/firmware/u-boot/board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg according to rcw_*_sdboot.bin
Yiping
4,727件の閲覧回数
dana_xiong
Hi Yiping,
Thank you for your answer !
 I would like to know how to compile and take effect after modifying the
packages/firmware/u-boot/board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg file ?
Dana
4,727件の閲覧回数
yipingwang
Hello Dana,
Please refer to the following line in configs/board/ls1043ardb/manifest.
rcw_sd=build/firmware/rcw/ls1043ardb/RR_FQPP_1455/rcw_1600_sdboot.bin
rcw_sd_sec=build/firmware/rcw/ls1043ardb/RR_FQPP_1455/rcw_1600_sdboot_sben.bin
You need to modify packages/firmware/rcw/ls1043ardb/RR_FQPP_1455/rcw_1600_sdboot.rcw
In LSDK 1906, atf image is used, RCW is not integrated to u-boot image.
Yiping
4,727件の閲覧回数
dana_xiong
Hi Yiping,
That means I can't just change the RCW configuration by modifying the
Dana
