Disable Interrupts before ADC_GetChanValue
alexit
Is it necessary to disable interrupts (sei;) before calling for a single ADC conversion? I have two ADC channels configured for two samples (total about 87us) and want to know if an interrupt occuring during this cycle will cause erratic measurements...
Thanks, D
ankur_kala
Hi David,
You dont need to disable the interrupt for Analog measurement. It should work identical in both cases.
ankur_kala
Hi David,
