CAN_LDD
2,619 次查看
carrielbr
To initialize the component in function CAN1_Init(NULL);
the boot is locked on the line while ( CAN_PDD_GetSoftResetState ( CAN0_BASE_PTR ) == CAN_PDD_NOT_RESET ) {}
Do what ?
标记 (4)
2,188 次查看
marek_neuzil
Could you provide more details about your application (and also the application) for analysis, please?
For example the issue can be cause by incorrect settings of clock (using of clock source that is not configured properly or external crystal does not work).
Marek Neuzil
2,189 次查看
marek_neuzil
Marek Neuzil
2,188 次查看
carrielbr
External crystal not work.
