Why MPC8306SOM using Flash m29W640gt ,but can't find the device in CW8.8 programmer device list.
1,868 次查看
00lirui
   Why MPC8306SOM using Flash m29W640gt ,but can't find the device in CW8.8 programmer device list??
1,736 次查看
yipingwang
Hello Li Rui,
It uses flash algorithm of M29W640DB, please refer to the template file in C:\Program Files\Freescale\CodeWarrior PA V8.8\bin\Plugins\Support\Flash_Programmer\EPPC\83xx, and which uses "amd" flash algorithm in C:\Program Files\Freescale\CodeWarrior PA V8.8\bin\Plugins\Support\Flash_Programmer\EPPC, you could find the information from C:\Program Files\Freescale\CodeWarrior PA V8.8\bin\Plugins\Support\Flash_Programmer\EPPC\FPDeviceConfig.xml.
Actually in your previous thread, I didn't think it was flash algorithm problem.
Would you please provide more detailed information in the previous thread?
Yiping
1,737 次查看
yipingwang
Hello Li Rui,
Yiping
