CodeWarrior8.8 for CodeWarrior TAP,MPC8309
tom3721
The software I used to use was Code Warrior8.8, and the emulator I used was CodeWarrior USB TAP. Now I have purchased CodeWarrior TAP, but this emulator cannot be correctly recognized in Code Warrior 8.8. Is there any additional program to correct this?
yipingwang
You need to apply Patch 8.8.6 to update CodeWarrior CCS USB driver to support CodeWarrior TAP.
Please login https://www.nxp.com, then download Patch 8.8.6 from "My NXP Account->Software Licensing and Support->View accounts->NXP Software->CodeWarrior Networked Suite - Specialist Level -> 8.8 CodeWarrior DS for Power Architecture, Professional Edition (Windows Hosted) WIN->Software Patch: CW PA v8.8.6 Windows - Patch.
laohu113
Hello, I have the same situation as you, but after I installed the patch, the result is the same as before, do you remember there are some special steps?
tom3721
我安装了补丁后就能正常使用了,没有碰到其它问题。
yipingwang
tom3721
Thank you very much. The problem has been solved after installing the patch.
