UJA1169ATK Maximum SPI Clock Speed
2,927件の閲覧回数
JarryZheng
The manual only sees that the minimum clock period is 250ns, but it does not tell me the maximum clock frequency.Can you tell me the maximum clock frequency supported by the SPI interface of the chip UJA1169ATK? Thank you!
2,917件の閲覧回数
guoweisun
2,918件の閲覧回数
guoweisun
Should be 4MHz.
2,910件の閲覧回数
JarryZheng
The clock frequency for SPI reads and writes must not exceed 4Mhz. Is that right?
