We have integrated the PF5020 PMIC with an NXP controller(IMXRT1176), and we have a couple of questions:
Is there a specific register bit or method to disable or lock out OTP (One-Time Programming) to prevent accidental writes during development? If it is, then provide a detail document or description.
The datasheet doesn’t show a detailed I2C communication read/write sequence. Is there any reference document or application note that outlines the proper sequence for safe register access?
Thanks in advance for your help.
Shivani
已解决! 转到解答。
Hi Shivani
Is there a specific register bit or method to disable or lock out OTP (One-Time Programming) to prevent accidental writes during development? If it is, then provide a detail document or description.[gw]No there is no.
[gw]Please see attached.
Hi Shivani
