NXP GUI PF5300 Power calculation
MichaelTao
When I use NXP GUI to do PF5300 calculation I have a question:
When I change Rja value, the Chip loss and Ext loss also changed. This confused me.
I think the Chip loss and Ext loss should not be change.
Tags (2)
MichaelTao
Hi guowei,
我尝试了一下好像这个NXP GUI计算有bug。输入的Rja值不能超过40。
我输入40以下的Rja值Tj是线性增加的。输入40的话,计算的结果和4一样。这个应该是个bug。
请问能否修复一下
guoweisun
热阻 跟温升跟功耗是有关系的。
假如你的热阻变化了温升也变了所以有可能功耗也在变,这个变化中唯独不变的是Tj(max)不能是这个Tj超过150C否则芯片就damage了
MichaelTao
Hi Guowei,
谢谢你的回复。
您说的这情况我理解了。
根据公式T_j=T_a+R_ja*P_loss
T_a:环境温度,
R_ja:热阻,
P_loss:PMIC的功率损耗
热阻越大结温不应该越高吗?
这里选用大的热阻,功率损耗反而减小了,结温也下降了,这一点我有点不能理解。
guoweisun
就是因为结温很大所以功耗不能大啊!
结温大功耗小Tj可大可小。
MichaelTao
Hi guowei,
请问能否修复一下
guoweisun
我们给出的热阻是下面圈出来的两个值,输入进入看看结果,其他的值没有意义
%3CLINGO-SUB%20id%3D%22lingo-sub-2203128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20GUI%20PF5300%20Power%20calculation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EWhen%20I%20use%20NXP%20GUI%20to%20do%20PF5300%20calculation%20I%20have%20a%20question%3A%26nbsp%3B%3C%2FP%3E%3CP%3EWhen%20I%20change%20Rja%20value%2C%20the%20Chip%20loss%20and%20Ext%20loss%20also%20changed.%20This%20confused%20me.%3C%2FP%3E%3CP%3EI%20think%20the%26nbsp%3BChip%20loss%20and%20Ext%20loss%20should%20not%20be%20change.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichaelTao_1-1762916349413.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichaelTao_1-1762916349413.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365075i6D9463DE1B5FE064%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichaelTao_1-1762916349413.png%22%20alt%3D%22MichaelTao_1-1762916349413.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichaelTao_2-1762916397538.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichaelTao_2-1762916397538.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365076i05CC3C4B1D6D5A98%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichaelTao_2-1762916397538.png%22%20alt%3D%22MichaelTao_2-1762916397538.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203382%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20GUI%20PF5300%20Power%20calculation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203382%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20thermal%20resistance%20we%20give%20is%20the%20two%20values%20circled%20below%2C%20enter%20them%20to%20see%20the%20results%2C%20the%20other%20values%20don't%20make%20sense%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1762934931078.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1762934931078.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365190iC1B2E0D2F2EACB6A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1762934931078.png%22%20alt%3D%22guoweisun_0-1762934931078.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203250%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20GUI%20PF5300%20Power%20calculation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203250%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20guowei.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20tried%20it%20seems%20like%20this%20NXP%20GUI%20calculation%20is%20buggy.%20the%20input%20Rja%20value%20can't%20be%20more%20than%2040.%3C%2FP%3E%3CP%3EI%20enter%2040%20or%20less%20the%20rja%20value%20Tj%20is%20increasing%20linearly.%20If%20I%20enter%2040%2C%20the%20calculation%20is%20the%20same%20as%204.%20This%20should%20be%20a%20bug.%3C%2FP%3E%3CP%3ECan%20you%20fix%20it%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichaelTao_0-1762926617743.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichaelTao_0-1762926617743.png%22%20style%3D%22width%3A%20207px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365130i8ED22C31CB958898%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichaelTao_0-1762926617743.png%22%20alt%3D%22MichaelTao_0-1762926617743.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203234%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20GUI%20PF5300%20Power%20calculation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203234%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EIt's%20just%20that%20the%20power%20consumption%20can't%20be%20big%20because%20the%20junction%20temperature%20is%20big!%3C%2FP%3E%0A%3CP%3EJunction%20temperature%20is%20large%20and%20power%20consumption%20is%20small%20Tj%20can%20be%20large%20or%20small.%3C%2FP%3E%3C%2FLINGO-BODY%3E
