How does the PCA9450 behave after its output is shorted?
已解决
跳至解决方案
1,915 次查看
tomo
Hi all,
How does the PCA9450 behave after the output is shorted?
I'm assuming that after a short occurs, all outputs are stopped once, but after that, does the PCA9450 try to restart the outputs like in HICCUP mode? Or does it keep stopping output?
tomo
标记 (1)
1 解答
1,906 次查看
TomasVaverka
Hi Miyazaki-san,
If the PMIC is in RUN/STBY mode, this behavior of all outputs are stopped once happens at the VRFLTx is unmasked, and after tFLT_POK_MSK, the regulators are trying to restart like HICCUP. But if masked, only the fault regulator stopped. Once short event removed, the output is normal, but there will be an interrupt and a fault status register assert.
BR, Tomas
在原帖中查看解决方案
2 回复数
1,907 次查看
TomasVaverka
Hi Miyazaki-san,
BR, Tomas
1,887 次查看
tomo
Thank you for your reply.
I understand the content of your reply.
thank you very much.
tomo
