How does the PCA9450 behave after its output is shorted?
1,321件の閲覧回数
tomo
Hi all,
How does the PCA9450 behave after the output is shorted?
I'm assuming that after a short occurs, all outputs are stopped once, but after that, does the PCA9450 try to restart the outputs like in HICCUP mode? Or does it keep stopping output?
tomo
タグ(1)
1,312件の閲覧回数
TomasVaverka
Hi Miyazaki-san,
If the PMIC is in RUN/STBY mode, this behavior of all outputs are stopped once happens at the VRFLTx is unmasked, and after tFLT_POK_MSK, the regulators are trying to restart like HICCUP. But if masked, only the fault regulator stopped. Once short event removed, the output is normal, but there will be an interrupt and a fault status register assert.
BR, Tomas
1,313件の閲覧回数
TomasVaverka
Hi Miyazaki-san,
BR, Tomas
1,293件の閲覧回数
tomo
Thank you for your reply.
I understand the content of your reply.
thank you very much.
tomo
